rcklssrabbit New Member 7 Member For: 6y 8m 9d Posted 15/08/17 10:02 AM Share Posted 15/08/17 10:02 AM So I've tried just about everything and scoured the forums but can't find a resolution to the problem I'm having. Car is an 04 XR6 turbo Ba 4 speed auto. Upgraded Intercooler and piping, throttle body relocation, GFB boost Controller, turbosmart actuator, shift kit, Tuned to 15psi but have set boost to 11 through controller, doesn't make a difference either way. Has new plugs, intake manifold gasket, all leaks checked, throttle body replaced as it was throwing codes. Tried standard boost solenoid too and cleaned it, bypassed straight from turbo to actuator- same problem. Nothing I do seems to change it. New fuel filter, changed plug gaps nothing makes a difference. Car feels sluggish to get moving but comes on boost okay and will hold whatever boost it's set at in a straight line, but if I get right up it and it loses traction (rarely ever and only ever up a hill) it dies in the ass, usually pops and has a breakdown for 30 seconds or so. What is causing it and why is it such a slug. Shouldn't be such an effort to break traction on 11-14psi, even on stockies. Won't even stall up on the spot, barely even in the wet sometimes. Traction is permanently turned off through the tune and fry's up fine cutting hoops so don't imagine that's the issue. WTF is wrong with it, starting to drive me insane. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,302 Member For: 16y 14d Gender: Male Location: Melbourne Posted 15/08/17 10:20 AM Share Posted 15/08/17 10:20 AM take it back to the tuner and show them the symptoms. They'll probably be able to fix it, if they can tune a falcon... Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 24d Gender: Male Location: Adelaide Posted 15/08/17 10:34 AM Share Posted 15/08/17 10:34 AM Piks of cutting hoops bruv ? 3 Link to comment Share on other sites More sharing options...
rcklssrabbit New Member 7 Member For: 6y 8m 9d Posted 15/08/17 10:55 AM Author Share Posted 15/08/17 10:55 AM When it's running right I would except it's a good 3 hours away in Sydney somewhere and no idea where it was done. Throwing an O2 sensor code too, so gonna replace that tomorrow and borrow some coilpacks of a mates car, but I feel like its a bigger issue than that. Don't understand why it's so gutless Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 29d Posted 16/08/17 09:29 AM Share Posted 16/08/17 09:29 AM Where do you start? Regap plugs, by all means put a new set of FORD coils in it, a blocked cat, wastegate stuck open, etc... What code dose the o2 sensor throw? to rich or to lean? air filter blocked? Do the basics first. 1 Link to comment Share on other sites More sharing options...
rcklssrabbit New Member 7 Member For: 6y 8m 9d Posted 16/08/17 01:21 PM Author Share Posted 16/08/17 01:21 PM (edited) Mate I think you're on the money. Did coil packs and o2 sensor today, made no difference. Was thinking cat so temp tested it (factory cat still) was red hot and twin pipes coming out of it were cold. Found an xforce system for sale from the turbo back dump pipe and all with 4" hi flo cat to 2.5" twin setup so snatched it up. Stripped exhaust back ready to bolt on and found wastegate wasn't shut, was loose as anything could almost fit my finger under it that's how bad it was, so pulled the manifold and turbo off, adjusted it so it's shut nice and tight now, cleaned everything up fixed an oil return leak while I was at it. Will post results tomorrow, it's not going to know itself, should get up and go now. Also what would you recommend gapping the plugs too on 15psi? Edited 16/08/17 01:22 PM by rcklssrabbit Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 4m 6d Gender: Male Location: North West Hot Hell,VIC Posted 16/08/17 08:42 PM Share Posted 16/08/17 08:42 PM .7 plug gap but you are going to hit more problems with overboost with that exhaust. Ported turbo and retune will be needed. If it killed the cat there is a problem with the tune anyway or either it had a previous missfire for quite a while before being fixed. Link to comment Share on other sites More sharing options...
rcklssrabbit New Member 7 Member For: 6y 8m 9d Posted 16/08/17 10:16 PM Author Share Posted 16/08/17 10:16 PM Pretty sure 0.7 is what I gapped them at , can't remember but will double check. Turbo is already ported I believe and I will be getting on the dyno soon, once all the issues are fixed. It was running rough for a while and previous owner has replaced coils so it's had a miss at some point, probably for a while. I'm thinking the reason is more that it's a factory cat with 200xxx kms with 2+ times the boost from factory lol Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 24d Gender: Male Location: Adelaide Posted 16/08/17 10:25 PM Share Posted 16/08/17 10:25 PM Cut some hoops before you dyno it get vids 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 1d Gender: Male Location: Perth Posted 17/08/17 03:27 AM Share Posted 17/08/17 03:27 AM If you cut a hoop doesn't it loose it's hoopness and there becomes a line? 1 Link to comment Share on other sites More sharing options...
