SHMIKO_S14A New Member 22 Member For: 6y 9m 19d Posted 03/08/17 11:27 AM Share Posted 03/08/17 11:27 AM Hi guys, So I reconnected my factory boost control solenoid today because it was disconnected/bypassed due to the tuner deciding to run a hose directly between the compressor housing and the wastegate actuator. To do this I had to remove the battery in order to get to it. After everything was back together I started the car up and it wasnt idling smoothly, then the car started idling at about 2000 - 2500rpm before almost stalling. I took the car for a drive and it was going ok once it was under load. I brought it back home and let it cool down for a couple of hours, then started it again and the car felt like it was running on three cylinders, super rough idle and the engine check light came on. Any ideas on what this could be? 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,128 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 03/08/17 11:34 AM Share Posted 03/08/17 11:34 AM A vacuum leak? Did you try swapping it back and seeing if it went back to normal? Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 2d Gender: Male Location: Canberra ACT Posted 03/08/17 12:59 PM Share Posted 03/08/17 12:59 PM Have you got something to pull the error codes for the Check Engine Light? Link to comment Share on other sites More sharing options...
SHMIKO_S14A New Member 22 Member For: 6y 9m 19d Posted 04/08/17 02:32 AM Author Share Posted 04/08/17 02:32 AM The car is running normally again now, the only other thing I touched when I was working on the car was the plug for the throttle body motor. I unplugged it, cleaned it out and plugged it back in and seems to have sorted it. At least temporarily anyway. I did a small amount of degreasing aswell so maybe some degreaser got into something and dried out. Cheers guys. Link to comment Share on other sites More sharing options...
