Typhoon Member 564 Member For: 19y 7m 1d Gender: Male Posted 05/03/18 08:24 AM Share Posted 05/03/18 08:24 AM (edited) On 2/28/2018 at 10:23 AM, arronm said: To make big big power you need RPM. To make RPM you need modified cams. It's always been the same. Nemz made 850RWKW on stock head and cams! Revs to 7000 - Obviously upgraded the valve springs. 158MPH in a 4220lbs car. Edited 05/03/18 08:30 AM by Typhoon Link to comment Share on other sites More sharing options...
DC-Auto New Member 24 Member For: 8y 4m 13d Gender: Male Location: GOLD COAST, QLD Posted 09/03/18 09:39 AM Author Share Posted 09/03/18 09:39 AM 18psi is all we could get on E85, wastegate needs some attention. havent decided whether to throw in some new spring combination into the (older generation) Tial 44mm (17psi), or upgrade the gate. im a bit dissapointed with only 50hp gain with e85, drive much nicer, idles better, but with the excessive fuel consumption I dont think it is worth running e85 at this boost Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 09/03/18 09:54 AM Share Posted 09/03/18 09:54 AM Just chuck in some more spring pressure. Springs are cheap as and it'll take you no time at all to chuck some extra or heavier ones in. Upgrading the gate is for flow and back pressure reasons, not raising the boost level. Link to comment Share on other sites More sharing options...
DC-Auto New Member 24 Member For: 8y 4m 13d Gender: Male Location: GOLD COAST, QLD Posted 09/03/18 10:50 AM Author Share Posted 09/03/18 10:50 AM 53 minutes ago, Puffwagon said: Just chuck in some more spring pressure. Springs are cheap as and it'll take you no time at all to chuck some extra or heavier ones in. Upgrading the gate is for flow and back pressure reasons, not raising the boost level. 100%, the reason to upgrade wasnt due to the extra boost, the older Tial 44mm gates are becoming increasingly difficult to find springs. I have to pay $140AU to purchase the springs I need from the States Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 09/03/18 11:09 AM Share Posted 09/03/18 11:09 AM It's still cheaper to get the springs though. In saying that a new gate will bring the design benefits, along with possibly less worn parts and as you mentioned, new springs are easier to get. Do you need any exhaust work or flange replacing to fit a new gate? Link to comment Share on other sites More sharing options...
DC-Auto New Member 24 Member For: 8y 4m 13d Gender: Male Location: GOLD COAST, QLD Posted 09/03/18 11:18 AM Author Share Posted 09/03/18 11:18 AM yep, it would be a $1000 to replace it Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 09/03/18 11:25 AM Share Posted 09/03/18 11:25 AM Is it dual port? Perhaps a different boost controller would get more out of it? Link to comment Share on other sites More sharing options...
DC-Auto New Member 24 Member For: 8y 4m 13d Gender: Male Location: GOLD COAST, QLD Posted 09/03/18 11:27 AM Author Share Posted 09/03/18 11:27 AM I have a brand new Mac solenoid being controlled by the Haltech, Ash (tuner) runs the same setup on his 7sec LSX RX7 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,127 Member For: 9y 2m 26d Gender: Male Location: South Australia Posted 09/03/18 11:40 AM Share Posted 09/03/18 11:40 AM (edited) If your tuner knows what they are doing then they will be able to tell you exactly what you should do. Edit: I'd still get some new springs though Edited 09/03/18 11:47 AM by Puffwagon Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 29d Gender: Male Location: Perth Posted 09/03/18 12:12 PM Share Posted 09/03/18 12:12 PM On 3/5/2018 at 4:24 PM, Typhoon said: Nemz made 850RWKW on stock head and cams! Revs to 7000 - Obviously upgraded the valve springs. 158MPH in a 4220lbs car. Stock cams, you sure. I dont think so. Link to comment Share on other sites More sharing options...
