Spoony Member 250 Member For: 13y 6m 13d Gender: Male Location: Brisbane Posted 28/05/17 09:32 PM Share Posted 28/05/17 09:32 PM I picked up some ebay poly rear bump stops. I've had no luck getting them to pop over the mounting lug/knob. So far I've tried greasing them up, trying to use a scissor jack between suspension arm and stop, no luck. I also tried putting using a large socket that locates in the stop but wide enough to no fall not the stop then jacking up that section of suspension. I got to a point where it looked scary/risky and stopped. Any other tips for young players? Cheers Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 28d Gender: Male Location: Perth Posted 30/05/17 05:55 AM Share Posted 30/05/17 05:55 AM Are you sure you have the correct part. Mine slipped straight on. Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 8m 9d Posted 30/05/17 06:13 AM Share Posted 30/05/17 06:13 AM (edited) Soak them in boiling water then massage them on. They will become pliable that way... Edit - obviously use caution, dont leave them in there to long etc etc... Edited 30/05/17 06:14 AM by MBAF Link to comment Share on other sites More sharing options...
Spoony Member 250 Member For: 13y 6m 13d Gender: Male Location: Brisbane Posted 30/05/17 10:39 PM Author Share Posted 30/05/17 10:39 PM Good idea, I actually had a light bulb moment of doing this laying in bed last night haha. Will give it a shot, cheers. 16 hours ago, arronm said: Are you sure you have the correct part. Mine slipped straight on. Yeah pretty sure, was yours poly or rubber though? I'd imagine rubber would pop over easy. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 28d Gender: Male Location: Perth Posted 31/05/17 12:02 AM Share Posted 31/05/17 12:02 AM Super pro poly spf2787k are you sure you arnt installing them upside down. Link to comment Share on other sites More sharing options...
Spoony Member 250 Member For: 13y 6m 13d Gender: Male Location: Brisbane Posted 31/05/17 12:27 AM Author Share Posted 31/05/17 12:27 AM While the rest of the car has Superpro bushes and joints these ones are just PolyPro, same design/item as Nolathane/Whiteline etc. One end is quite open so it can only go one one way. http://www.nolathane.com.au/product_detail.php?part_number=47344&sq=2056 Link to comment Share on other sites More sharing options...
Spoony Member 250 Member For: 13y 6m 13d Gender: Male Location: Brisbane Posted 02/06/17 03:59 AM Author Share Posted 02/06/17 03:59 AM Hmmm the hot/boiling water idea seems to have zero effect on the Poly. :( Link to comment Share on other sites More sharing options...
turboknapp Donating Members 783 Member For: 17y 1m 1d Gender: Male Location: perth w.a Posted 02/06/17 04:37 AM Share Posted 02/06/17 04:37 AM Can you get them started, then put a block of wood between them and the suspension arm and jack the arm up. That is normally the easiest way to do it Link to comment Share on other sites More sharing options...
Spoony Member 250 Member For: 13y 6m 13d Gender: Male Location: Brisbane Posted 02/06/17 05:12 AM Author Share Posted 02/06/17 05:12 AM Got them on using a 36mm socket (one I use for hub nuts) reversed into the stop. Then after many sketch random slips managed to lever them on with a long tyre lever bar. Link to comment Share on other sites More sharing options...
