Lunchietey Member 84 Member For: 13y 8m 17d Gender: Male Location: WA Posted 20/03/18 11:07 AM Author Share Posted 20/03/18 11:07 AM Intake side finished(MAP and wiring, butterflies removed, oil feed installed, oil switch replaced, FPR, wiring for gauges in place and hose for boost gauge run into cabin) intercooler piping and installation finished, water lines and oil feed all done(intake side was a bitch) and last water hoses replaced, new wastegate (turbosmart IWG @5psi) finally arrived and fitted as per instructions. Ready for turbo bolt in tomorrow and connect all lines to it. Just still need to drill drain line. Once the drain is in, I'll drain the oil and flush as well as install the sandwich plate and sender's for oil temp/press. Not a lot left to do. Dropping the ecu off to Ralph for initial flash tomorrow too. Hopefully the postie drops the last few bits off!(waiting on one gauge, crossover vibration mounts etc, just little stuff) Woohoo! 2 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,292 Member For: 16y 10d Gender: Male Location: Melbourne Posted 20/03/18 11:09 AM Share Posted 20/03/18 11:09 AM good progress, mate 1 Link to comment Share on other sites More sharing options...
Lunchietey Member 84 Member For: 13y 8m 17d Gender: Male Location: WA Posted 20/03/18 11:33 AM Author Share Posted 20/03/18 11:33 AM Oh and replaced PCV and installed the check valve in the line, thanks @NA_TURBO 1 Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 12y 4m 20d Gender: Male Location: WA, Perth Posted 21/03/18 01:16 AM Share Posted 21/03/18 01:16 AM hey @Lunchietey, did you use a stock check valvue at the rear PCV port? Reason I am asking, is I still have not installed my damn catch can, cause I have no idea what piping and pcv check valve to get, before I install the catch can. Link to comment Share on other sites More sharing options...
Lunchietey Member 84 Member For: 13y 8m 17d Gender: Male Location: WA Posted 21/03/18 02:10 AM Author Share Posted 21/03/18 02:10 AM Yes I used a genuine ford check valve and installed it as per the pic further up. They had to order it and it was around $30 I think. A new PCV is only $9 or something. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 24d Gender: Male Location: Perth Posted 21/03/18 04:42 AM Share Posted 21/03/18 04:42 AM (edited) Depending on boost level. Stock one way valve may not be strong enough. I use an aftermarket one so my catch can doesn't get pressurised Edited 21/03/18 04:42 AM by arronm Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 10y 2m 8d Gender: Male Location: SW Sydney Posted 21/03/18 06:48 AM Share Posted 21/03/18 06:48 AM (edited) @arronm what check valve do you use? Had the same thought RE pressure rating, also will be doing a bigger size line than factory when I get around to doing my catch can setup Edited 21/03/18 06:50 AM by camo86T Link to comment Share on other sites More sharing options...
Lunchietey Member 84 Member For: 13y 8m 17d Gender: Male Location: WA Posted 21/03/18 08:01 AM Author Share Posted 21/03/18 08:01 AM Being an NA block, boost levels won't be a problem Link to comment Share on other sites More sharing options...
Lunchietey Member 84 Member For: 13y 8m 17d Gender: Male Location: WA Posted 22/03/18 10:14 AM Author Share Posted 22/03/18 10:14 AM Almost done. A few little bits tomorrow and refill fluids after etc and pick the ECU up. 50% chance of starting her up tomorrow but may end up being Monday if I can't get everything 100%. Either way, exhaust won't be finished until next week. It's my Birthday Saturday so Sunday I won't be moving a whole lot haha 1 Link to comment Share on other sites More sharing options...
Lunchietey Member 84 Member For: 13y 8m 17d Gender: Male Location: WA Posted 23/03/18 01:58 AM Author Share Posted 23/03/18 01:58 AM (edited) Well the f**king steel line into the water pump leaks. Gotta unbolt a heap of crap to fix ? Edited 23/03/18 01:59 AM by Lunchietey Link to comment Share on other sites More sharing options...
