Rickybobby New Member 15 Member For: 7y 5m 14d Posted 21/01/17 11:50 PM Share Posted 21/01/17 11:50 PM Hey guy n gals, running a aftermarket stereo cause my icc isn't workin and I can't deal with silence. where is a good place to tap into to get a ignition power supply to turn the headunit on. I have run a seperate wire for constant and ground wires just not sure if the best place to run a power wire. Cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 21/01/17 11:52 PM Share Posted 21/01/17 11:52 PM use the positive from the 12v outlet socket for ignition power. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 29d Gender: Male Location: Perth Posted 22/01/17 12:27 AM Share Posted 22/01/17 12:27 AM (edited) Bluetooth plug. Behind fuse box. You can get all three wires there. Yelllow is +. Black/yellow is ACC and balck is - You can use a four way connector like I did (car plug is on the right, or just male spade connectors. The green wire is mute Edited 22/01/17 12:42 AM by arronm 1 Link to comment Share on other sites More sharing options...
Rickybobby New Member 15 Member For: 7y 5m 14d Posted 22/01/17 12:33 AM Author Share Posted 22/01/17 12:33 AM I had a mate who used the 12vplug and it cancels out the windows when the headunit is running. Draws to much power for the motor to work. Hate to be a pain but what one is the Bluetooth plug and what wire of it do I use for just mains power? Photo reference would be sweet!!! I originaly had a aux plugged in but it created way to much interference noise. is that the same plug? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 15d Gender: Male Location: Melbourne Posted 22/01/17 12:35 AM Share Posted 22/01/17 12:35 AM Just now, Rickybobby said: I had a mate who used the 12vplug and it cancels out the windows when the headunit is running. Draws to much power for the motor to work. I had a mates mate that did nothing and it did nothing to nothing... don't be ridiculous. The 12v plug is not even on the same circuit as the power window motors. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 9y 3d Gender: Male Location: Canberra ACT Posted 22/01/17 05:17 AM Share Posted 22/01/17 05:17 AM The good thing about doing what Arronm suggests is you can easily isolate your own wiring from the factory gear. If you have an electrical issue, it's a quick unplug and you are back to factory spec so you can eliminate your additional wiring and accessories as the cause. I've got an additional power socket for my Bluetooth hands free adaptor and my gauges wired that way. Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 8m 10d Posted 22/01/17 06:33 AM Share Posted 22/01/17 06:33 AM 6 hours ago, arronm said: Bluetooth plug. Behind fuse box. You can get all three wires there. Yelllow is +. Black/yellow is ACC and balck is - You can use a four way connector like I did (car plug is on the right, or just male spade connectors. The green wire is mute This is the best way by far. I just ran spades and slotted them in. Ran the same head unit in both falcons and makes for easy removal also. Link to comment Share on other sites More sharing options...
