LazyBrennan Donating Members 683 Member For: 13y 29d Gender: Male Location: Baldivis, Wait Ages. Posted 20/12/16 03:01 AM Share Posted 20/12/16 03:01 AM Gday guys I am having an issue with my aux cable in my bf2. When I plug it up to my phone the left speaker isn't working. When I play music from a CD or the radio it all works perfectly fine. I tried hooking my phone up to another aux in another bf falcon and it worked perfectly fine. So I transferred that aux cable to my car and the left speaker still doesn't work. Has anyone had this issue before or know what else I could try to fix it? Link to comment Share on other sites More sharing options...
Piers41 New Member 9 Member For: 7y 4m Posted 20/12/16 03:25 AM Share Posted 20/12/16 03:25 AM The aux imput socket may need a clean this is usually what causes an aux imput to play through one speaker, this us nit a ford specific fix so may not work but this is what generally causes it to play thiugh inly one speaker Link to comment Share on other sites More sharing options...
LazyBrennan Donating Members 683 Member For: 13y 29d Gender: Male Location: Baldivis, Wait Ages. Posted 20/12/16 03:44 AM Author Share Posted 20/12/16 03:44 AM Cheers for that mate. Is there anything in particular I should wash them with? Any type of sprays or just use a clean cloth? Link to comment Share on other sites More sharing options...
LazyBrennan Donating Members 683 Member For: 13y 29d Gender: Male Location: Baldivis, Wait Ages. Posted 20/12/16 05:04 AM Author Share Posted 20/12/16 05:04 AM Still no luck. Tried cleaning the connectors and still nothing on the left. Tried the same cable again in another bf and it works perfectly. I actually love toads. ❤️ 1 Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 4m 26d Gender: Male Location: Probably above atmospheric pressure Posted 20/12/16 05:19 AM Share Posted 20/12/16 05:19 AM (edited) Edited 20/12/16 05:24 AM by -Stever- 2 Link to comment Share on other sites More sharing options...
LazyBrennan Donating Members 683 Member For: 13y 29d Gender: Male Location: Baldivis, Wait Ages. Posted 20/12/16 05:30 AM Author Share Posted 20/12/16 05:30 AM Yeah ok so for some reason I suddenly became Ih8toads ? But yeah I've tried cleaning the connections with no luck and tried 2 different cables now. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 4m 26d Gender: Male Location: Probably above atmospheric pressure Posted 20/12/16 05:32 AM Share Posted 20/12/16 05:32 AM Install aftermarket head unit with aux input Works an astounding 100% of the time, every time, in my experience 2 Link to comment Share on other sites More sharing options...
Piers41 New Member 9 Member For: 7y 4m Posted 20/12/16 05:41 AM Share Posted 20/12/16 05:41 AM There could be corrosion on the aux imput circuit board not sure how to check that out though Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 11y 3m 22d Gender: Not Telling Posted 20/12/16 09:45 AM Share Posted 20/12/16 09:45 AM (edited) 4 hours ago, LazyBrennan said: But yeah I've tried cleaning the connections with no luck and tried 2 different cables now. aw ya poor thing, mine works farking perfectly, I amp the output from the stock ICC too. Worst case it's the ICC as mentioned above but where the aux cable connects you might want to try swapping the inputs and seeing if the opposite speaker is working. This would suggest there is an issue with the ICC or the wiring between that point and the ICC. more likely to be the ICC if this is the case... 6 hours ago, LazyBrennan said: Any type of sprays or just use a clean cloth? For circuit board/connections you can buy electrical contact cleaner. for normal connections I just give it a blast of inox and insert and remove a few times. Edited 20/12/16 09:51 AM by skidxr6t Link to comment Share on other sites More sharing options...
LazyBrennan Donating Members 683 Member For: 13y 29d Gender: Male Location: Baldivis, Wait Ages. Posted 20/12/16 10:22 AM Author Share Posted 20/12/16 10:22 AM Well it seems to be working now after spraying the connection :D Cheers for the help guys! 1 Link to comment Share on other sites More sharing options...
