Piers41 New Member 9 Member For: 7y 3m 29d Posted 20/12/16 01:35 AM Share Posted 20/12/16 01:35 AM Hi everyone, Im totally stumped as to why my car wont start, All I get is single click or two when pressing the starter button. This began a week ago, when my battery went flat, I replaced the battery and then 2days ago it shutdown while I was driving which I think is related to the alternator but now with a freshly charged battery I get nothing, the dash lights up as per normal with no odd warning lights but I dont get any ignition just a click click, please any suggestions, I dont think im hearing the fuel pump prime either Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,282 Member For: 16y 8d Gender: Male Location: Melbourne Posted 20/12/16 01:37 AM Share Posted 20/12/16 01:37 AM Sounds like a stuffed alternator. Re-charge the battery separately to the car and then if it starts straight away then your alternator is just not charging the battery enough. 1 Link to comment Share on other sites More sharing options...
Piers41 New Member 9 Member For: 7y 3m 29d Posted 20/12/16 01:46 AM Author Share Posted 20/12/16 01:46 AM (edited) I tried this but im still getting nothing, ive even had a jumper pack on the fresh battery, it seems like the smartlock has isolated things but the the red warning hand isnt flashing, I also left tge key in the on b position for 30 mins to see if that fuxed it but still just a click inside the cabin, could the fuel isolation system have tripped Edited 20/12/16 01:48 AM by Piers41 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,282 Member For: 16y 8d Gender: Male Location: Melbourne Posted 20/12/16 01:49 AM Share Posted 20/12/16 01:49 AM If you're getting that "click click" then it's not the immobiliser. Time for an auto-elec if the car isn't starting with a full battery and is only clicking the starter motor (symptom of low battery cold cranking amps) 1 Link to comment Share on other sites More sharing options...
Piers41 New Member 9 Member For: 7y 3m 29d Posted 20/12/16 01:51 AM Author Share Posted 20/12/16 01:51 AM I dont even think the starter is click I think its just the relay in the cab Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,282 Member For: 16y 8d Gender: Male Location: Melbourne Posted 20/12/16 01:52 AM Share Posted 20/12/16 01:52 AM Yes, of course I mean the relay for the starter motor circuit which clicks on low battery (as it doesn't have enough power to push the starter motor). 1 Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 7y 10m 29d Gender: Not Telling Location: Radioactive wasteland Posted 20/12/16 01:53 AM Share Posted 20/12/16 01:53 AM New battery then goes flat. Your alternator is shagged and it has killed that new battery. You need a new battery and alternator. Try with a fresh battery. If it starts you definitely need to source an alternator. 1 Link to comment Share on other sites More sharing options...
Piers41 New Member 9 Member For: 7y 3m 29d Posted 20/12/16 01:56 AM Author Share Posted 20/12/16 01:56 AM I just want it start to drive to get my alternator replaced, I had the battery on a ctek trickle charger it seemed to think the battery was ok and charged it up Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 22d Gender: Male Location: Perth Posted 20/12/16 01:59 AM Share Posted 20/12/16 01:59 AM Check the connection at the alternator. Put a voltmeter on the battery while car is running. Should be greater than 13.5 Try checking the voltage across the battery while starting. 1 Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 7y 10m 29d Gender: Not Telling Location: Radioactive wasteland Posted 20/12/16 02:40 AM Share Posted 20/12/16 02:40 AM 42 minutes ago, Piers41 said: I just want it start to drive to get my alternator replaced, I had the battery on a ctek trickle charger it seemed to think the battery was ok and charged it up If the alternator wasn't charging properly and you flattened the battery that trickle charger won't fix that battery. It might say it's got good voltage but the amps won't be there to turn the motor. 1 Link to comment Share on other sites More sharing options...
