agruyich New Member 2 Member For: 7y 6m 21d Posted 28/09/16 03:35 PM Share Posted 28/09/16 03:35 PM Hey Guys, I Recently purchased a BA XR6 that was orginally N/A that has a had a turbo conversion but on the N/A engine. I have read a few threads and no some of the guys here have experience with turboing the N/A engine. As the car has already been converted, I am looking to tune the car now. What would be max amount of boost the stock engine can handle? I am assuming it is around 7psi or so? Has anyone ran 10psi safely on N/A internals? I am looking for around to have around 250rwkw to 300rwkw. The car already has a Walbro fuel pump installed and I have a set of 42 Ib injectors not installed though. I understand with N/A internals it will never reach 300rwkw, but in your opinion what do you think the max would be I could push it? Also how much can you run through the T5 and standard clutch before it sh*ts itself? Plan is to slowly build the car and when the engine sh*ts itself purchase a XR6T engine with T56 box. Planned mod list is as follows .Walbro fuel pump .42 Ib injectors .Turbo back exhaust .Valve springs (no on N/A engine though) .SCT X3 Flash .K&N Air filter From experience do you think above mods will support 250rwkw to 300rwkw? Also for BA's are the brakes the same for N/A xr6 and the xr6 turbo? Im pretty sure the brakes changed on the BF models? not sure though! Anyone recommend a place in melbourne to get car tuned? From what I have read nizpro is good? Cheers Adam Link to comment Share on other sites More sharing options...
BAXRTUTE Gold Donating Members 2,639 Member For: 8y 1d Posted 28/09/16 09:04 PM Share Posted 28/09/16 09:04 PM buy a BF mk2 engine and t56... 5sp will struggle with any power.... na block will struggle also... save ya money Adam and upgrade asap. good luck and welcome to the forum 1 Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 11y 3m 21d Gender: Not Telling Posted 28/09/16 10:32 PM Share Posted 28/09/16 10:32 PM convert the NA engine to run on E85 and see how that goes 1 Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 7y 10m 30d Gender: Not Telling Location: Radioactive wasteland Posted 29/09/16 12:12 AM Share Posted 29/09/16 12:12 AM Bigger injectors and e85 would be interesting. I don't think you'll be able to safely push that motor past 250rwkw on 98 pulp. That box won't handle it either. Cris is on the money. Save up and get a bf11 onwards block and a t56 and then push it. Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,673 Member For: 15y 11m 2d Gender: Male Location: adelaide hills- 'race air' central Posted 30/09/16 10:25 AM Share Posted 30/09/16 10:25 AM box is butter. ba xr6t's had weak enough rods.... Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,019 Member For: 8y 11m 27d Gender: Male Location: Canberra ACT Posted 30/09/16 10:33 AM Share Posted 30/09/16 10:33 AM Yep N/A and XR6T brakes on BA are the same (unless optioned). BF onwards turbos have bigger discs but same calipers. That's all for the front - not sure if BF turbos had different rears to N/A. Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 7y 10m 30d Gender: Not Telling Location: Radioactive wasteland Posted 30/09/16 11:09 AM Share Posted 30/09/16 11:09 AM My bf1t has 328mm on the rear 322mm fronts. What were they standard? I think that's a weird size. Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,673 Member For: 15y 11m 2d Gender: Male Location: adelaide hills- 'race air' central Posted 30/09/16 12:26 PM Share Posted 30/09/16 12:26 PM sounds like pbr's premium c6 calliper and disc. I have the same on mine- rear is larger diameter than the front but thinner. these were on the au3 t series. Link to comment Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 7y 10m 30d Gender: Not Telling Location: Radioactive wasteland Posted 30/09/16 02:09 PM Share Posted 30/09/16 02:09 PM Ex cop car if that makes anymore sense. No cop chip unfortunately. Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 7y 8m 4d Posted 30/09/16 02:39 PM Share Posted 30/09/16 02:39 PM 3 hours ago, ROB83R said: My bf1t has 328mm on the rear 322mm fronts. What were they standard? I think that's a weird size. Standard size for our cars. None xr came out with a sub 300mm disc. 2 hours ago, Panda Eyes said: sounds like pbr's premium c6 calliper and disc. I have the same on mine- rear is larger diameter than the front but thinner. these were on the au3 t series. This! 27 minutes ago, ROB83R said: Ex cop car if that makes anymore sense. No cop chip unfortunately. No such thing as a cop chip on the later falcons. Yours looks to be a good example though. Ive seem some sh*t ones around. Specially up here on the coast Link to comment Share on other sites More sharing options...
