FG F6 Mii 432rwkws 1080Nm's
blow off
  • Member For: 15y 8m 21d
Rear guards pumped 25mm and a re-spray
Aodhan DS01 rims in 18" 9.5+15 and 10.5+22 wrapped in 245/40 and 275/35 Toyo R888's
  • Like 4
  • Silver Donating Members
  • Member For: 12y 1m 11d
Soooo...you went to the effort of pumping your guards, only to run stretched tyre widths that you could easily have run on stock guards? Riiiiiiight...
Space your control blade and you'd be able to fit some 315 or 335's under the rear with the right offset!
  • Like 2
Get 1 in every crowd...
R888's are a massive tyre, 275 are equivalent to 295's in other makes. Do they look like they are stretched.. NO. They sit flush with the rims.
With the offset the rears poked 24mm prior to guard rolling and now sit 1mm to flush.
How these things squat under load any larger tyre will hit the in guards.. Riiiiight.
Achieved what was desired, get it to hook up and look tuff.
Edited by blow off
  • Like 3
  • MattyP
  • Cruise Control
  • Member For: 11y 11m 20d
You can still see a little stretch going on, not sure what size those tyres come in but 305s back there would be mint!
  • MattyP
  • Cruise Control
It's definitely not over the top
I suppose I'm a big fan of the widest rear tyres you can possibly fit
nice choice regardless op
I think I really just hate the stance crowd, function over form please
how do the r888s hook up mate?
Tried just about every quality tyre on my Ute (600kws). R888's are by far best, don't waste your money on anything else. Had 315 on it with a 10" rim.
R888's even work great when cold and just get better when warm.
Best I ever got was 12000km out of a set with most the time on full boost.
If you nail the F6 in first (ZF) it will slightly let go, any other gears all good. No Spinning. 430rwks & over 1000NM
  • Like 5
