singh87 Member 50 Member For: 10y 9m 1d Gender: Male Posted 17/05/16 02:30 PM Share Posted 17/05/16 02:30 PM General Tech P04443 fault code Started by singh87, 30 minutes ago fg turbo fault code singh87 Member 47 posts Gender:Male Member For:2y 9m 28d · #1 Posted 30 minutes ago · Hi everyone!! Anyone ever come across fault code P04443?? Emission control purge seloniod fault?? How to fix it? Try clear wid sct wont help!! Checked selonoid its clucking!! Who can help here?? I am located south east melb! Thxx Link to comment Share on other sites More sharing options...
Robos F6 Donating Members 407 Member For: 15y 1m 18d Gender: Male Location: Vic Posted 10/09/16 05:50 AM Share Posted 10/09/16 05:50 AM (edited) I suggest you test to see if the valve is really opening when it clicks. (there should be vacuum on both pipes when it is open) Clicking is only a sign that the valve's solenoid coil is healthy. You say your valve is clicking. Do you mean continually? If you park in the sun for 1 hour and then start the engine, the valve should open + close a couple of times at the most. Edited 10/09/16 05:51 AM by Robos F6 Link to comment Share on other sites More sharing options...
