sprouly07 Donating Members 62 Member For: 9y 9m 11d Gender: Male Location: Townsville Posted 28/04/16 07:59 AM Share Posted 28/04/16 07:59 AM Hey guys I had been noticing a bit of a boost leak and when I put it on the dyno about a month ago was suspicions were confirmed. Would make 21pound and then fall off to 17 on the high boost tune and then with the everyday tune it would make 18 and then fall off to about 15-16. Started to investigate and found the bov was on back to front. So what would usually be the outlet was now the inlet. After changing it back to how it should be it now holds 21 pound and goes a lot better. Is there a reason why it would be leaking through because it was back to front? Or could it just be a sign that it's not that healthy and may need replacing. I can't think of a reason why it leak being installed backwards. Cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 28/04/16 11:19 AM Share Posted 28/04/16 11:19 AM what make/model of BOV is it? Link to comment Share on other sites More sharing options...
Jamie_d Member 219 Member For: 9y 15d Gender: Male Location: Wadalba 2259 NSW Posted 28/04/16 11:22 AM Share Posted 28/04/16 11:22 AM Picture of bov? Makes sense. Not made to seal with pressure on a vent port. Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 11y 11m 20d Gender: Male Location: Central Coast Posted 28/04/16 09:25 PM Share Posted 28/04/16 09:25 PM Block bov /end thread 3 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 28/04/16 11:46 PM Share Posted 28/04/16 11:46 PM Whilst I agree with this ^^, it doesn't help to answer the bloke's question - he's already resolved the leak by putting the BOV around the correct way haha 2 Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 11y 11m 20d Gender: Male Location: Central Coast Posted 29/04/16 01:56 AM Share Posted 29/04/16 01:56 AM Even if it was around the incorrect way blocking fixes it /end thread 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,303 Member For: 16y 14d Gender: Male Location: Melbourne Posted 29/04/16 01:57 AM Share Posted 29/04/16 01:57 AM Link to comment Share on other sites More sharing options...
sprouly07 Donating Members 62 Member For: 9y 9m 11d Gender: Male Location: Townsville Posted 29/04/16 08:59 AM Author Share Posted 29/04/16 08:59 AM Standard bov. I wasnt asking how to fix it. Was asking if anyone had any ideas why it was doing what it was doing. But thanks for your input. Link to comment Share on other sites More sharing options...
Jamie_d Member 219 Member For: 9y 15d Gender: Male Location: Wadalba 2259 NSW Posted 29/04/16 10:17 AM Share Posted 29/04/16 10:17 AM Search bosch bypass valve. Weird diaphragm setup in them. Might give you a visual as to why it leaks the wrong way around. Link to comment Share on other sites More sharing options...
sprouly07 Donating Members 62 Member For: 9y 9m 11d Gender: Male Location: Townsville Posted 29/04/16 10:38 AM Author Share Posted 29/04/16 10:38 AM 16 minutes ago, Jamie_d said: Search bosch bypass valve. Weird diaphragm setup in them. Might give you a visual as to why it leaks the wrong way around. Cheers for that. In my mind I thought as long as it had the manifold pressure there it would have held closed unless there was a leak/ hole in the diaphragm. But then it would have leaked regardless of if it was installed the correct way or not. Link to comment Share on other sites More sharing options...
