Big Barra BF Build
  • Member For: 11y 2d
14 hours ago, HI PSI said:
How did you go with the main studs? Did you get them to bottom?
I dunno if you know but you know how the windage tray is spot weld to those 2 thicker parts? Well I drilled them off and just used the thin part of the tray.. and just wound the studs up a few turns.
  • I'm getten too old for this s**t
  • Bronze Donating Members
  • Member For: 11y 9d
Good to meet and chat with you down at MTQ yesterday Jamie
Keep us updated on progress mate and think about the intercooler
  • Member For: 17y 10m 22d
From memory, 6 mm ball bearings are meant to be inserted....
 I called Brad (Atomic) when I installed my studs, as they wouldn't bottom. He told me that I needed to install 6 mm ball bearings into the block, so that they would. happen.  Not bottoming the studs may lead to inaccurate tensioning.
Edited by HI PSI
