JamieXR Member 21 Member For: 11y 11d Posted 27/02/16 01:44 AM Author Share Posted 27/02/16 01:44 AM 14 hours ago, HI PSI said: How did you go with the main studs? Did you get them to bottom? I dunno if you know but you know how the windage tray is spot weld to those 2 thicker parts? Well I drilled them off and just used the thin part of the tray.. and just wound the studs up a few turns. Link to comment Share on other sites More sharing options...
JamieXR Member 21 Member For: 11y 11d Posted 27/02/16 01:58 AM Author Share Posted 27/02/16 01:58 AM Link to comment Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 11y 18d Gender: Male Location: A big bridge over a river in South Australia Posted 27/02/16 07:38 AM Share Posted 27/02/16 07:38 AM Good to meet and chat with you down at MTQ yesterday Jamie Keep us updated on progress mate and think about the intercooler 1 Link to comment Share on other sites More sharing options...
HI PSI Member 1,572 Member For: 17y 11m Gender: Male Location: Central Queensland Posted 27/02/16 11:12 AM Share Posted 27/02/16 11:12 AM 9 hours ago, JamieXR said: I dunno if you know but you know how the windage tray is spot weld to those 2 thicker parts? Well I drilled them off and just used the thin part of the tray.. and just wound the studs up a few turns. From memory, 6 mm ball bearings are meant to be inserted.... Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 25d Gender: Male Location: Adelaide Posted 27/02/16 11:15 AM Share Posted 27/02/16 11:15 AM Correct Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 23d Gender: Male Posted 27/02/16 11:28 AM Share Posted 27/02/16 11:28 AM You want to put what where now?.... Link to comment Share on other sites More sharing options...
JamieXR Member 21 Member For: 11y 11d Posted 28/02/16 10:11 AM Author Share Posted 28/02/16 10:11 AM 22 hours ago, HI PSI said: From memory, 6 mm ball bearings are meant to be inserted.... Huuh? Lol Link to comment Share on other sites More sharing options...
HI PSI Member 1,572 Member For: 17y 11m Gender: Male Location: Central Queensland Posted 28/02/16 10:14 AM Share Posted 28/02/16 10:14 AM (edited) I called Brad (Atomic) when I installed my studs, as they wouldn't bottom. He told me that I needed to install 6 mm ball bearings into the block, so that they would. happen. Not bottoming the studs may lead to inaccurate tensioning. Edited 28/02/16 10:27 AM by HI PSI Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 29d Gender: Male Location: Perth Posted 28/02/16 11:43 AM Share Posted 28/02/16 11:43 AM They don't need to be bottomed 1 Link to comment Share on other sites More sharing options...
JamieXR Member 21 Member For: 11y 11d Posted 28/02/16 11:57 AM Author Share Posted 28/02/16 11:57 AM On Saturday, February 27, 2016 at 9:42 PM, HI PSI said: From memory, 6 mm ball bearings are meant to be inserted.... Once the main cap bolts are torqued up there is no way the studs will move Link to comment Share on other sites More sharing options...
