jg33y113 New Member 2 Member For: 8y 2m 10d Posted 13/02/16 06:49 AM Share Posted 13/02/16 06:49 AM Hello, I have a 2010 FG xr6 turbo with approx 30K kilometers on it. Did an oil change on it today and even cleaned out the turbo line feed filter, anyway to make a long story short, when it was all back together and I went to start it it won't crank. It's as if its not in park the lights come on but it refuses to crank over! I used a little degreaser under the sump to clean it up but nothing else was messed with. I've been looking at a few posts about a problem I'm having but cant seem to find a solution... Anyone had a similar experience? thanks Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 21d Gender: Male Posted 13/02/16 12:36 PM Share Posted 13/02/16 12:36 PM left the keys in it & the battery doesn't have voltage? Link to comment Share on other sites More sharing options...
jg33y113 New Member 2 Member For: 8y 2m 10d Posted 13/02/16 12:44 PM Author Share Posted 13/02/16 12:44 PM checked a couple of things, fuel was priming voltage was 12.5 battery perfect pulled the starter wire off and tried starting and it was getting 12v at the wire, so I cleaned the contact and put it back on....problem fixed. I must have bumped it with the spanner getting the oil filter screen off the block. Thanks for the reply... Link to comment Share on other sites More sharing options...
