PaulTF New Member 10 Member For: 8y 10m 21d Posted 19/09/15 04:55 AM Share Posted 19/09/15 04:55 AM Hey all,Quick question. Got an 04 ba running an 07 bf motor. I have 2 custom tunes, 8 and 11psi, through an SCT Flash box. With either tune it runs 8psi. Bog stock apart from this. Testing the boost solenoid without power, it doesn't boost. I'm guessing this means that without voltage, the solenoid stays open and allows pressure to open the wastegate.So, if the solenoid was faulty (not closing properly), would it then in turn bleed pressure and open the wastegate prematurely not allowing for full boost ie 11psi?I've ruled out boost leaks, spark plugs etc.Thanks in advance for your replies. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 27d Gender: Male Location: Perth Posted 19/09/15 05:09 AM Share Posted 19/09/15 05:09 AM Correct. Link to comment Share on other sites More sharing options...
PaulTF New Member 10 Member For: 8y 10m 21d Posted 19/09/15 06:12 AM Author Share Posted 19/09/15 06:12 AM Awesome. Could I have stuffed it when I used MAF sensor cleaner to perform the "maintenance" instead of WD40? Link to comment Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 12y 8m 18d Gender: Male Location: South West QLD Posted 19/09/15 06:46 AM Share Posted 19/09/15 06:46 AM Used maf sensor cleaner. Car now thinks it is a Holden. Doesn't recognize anything associated with turbos. Link to comment Share on other sites More sharing options...
PaulTF New Member 10 Member For: 8y 10m 21d Posted 19/09/15 07:08 AM Author Share Posted 19/09/15 07:08 AM Ha ha, nice, must've forgotten how to Ford Curious to find out if wd40 is used to clean or lubricate the solenoid Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 18d Gender: Male Posted 20/09/15 06:36 AM Share Posted 20/09/15 06:36 AM Think it's a bit of both. I find it hard to see that wd40 has killed it. I'd double check that it hasn't blown a hose off or something Link to comment Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 10y 10m 25d Gender: Male Location: NOR Perth Posted 21/09/15 05:04 AM Share Posted 21/09/15 05:04 AM Pretty sure my Ford uses WD40 when I ask them to do the maintenance each service (yes I know its a simple job and I should really be doing it myself lol) Would have to double check with them....but have done it for 50,000kms and no issue so far... Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 18d Gender: Male Posted 21/09/15 12:12 PM Share Posted 21/09/15 12:12 PM Is it a serviceable thing ford would do? I'm thinking if it's not in the book they wouldn't do it Link to comment Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 10y 10m 25d Gender: Male Location: NOR Perth Posted 21/09/15 12:54 PM Share Posted 21/09/15 12:54 PM Yeh dont think it is (when I approached another dealer they told me no one has ever asked them to do it before lol).I had to print the tutorial off here (think it was for BA/BF) and then they did it...since tutorial says wd40 I assume they have been doing the same (will double check next time I call them).Only reason they do it is cause they wont charge 30min blocks...and they do the earls turbo line clean to make up the 1hr block lol Link to comment Share on other sites More sharing options...
