turbotrana Member 2,586 Member For: 21y 25d Gender: Male Posted 27/08/15 07:06 AM Share Posted 27/08/15 07:06 AM I replaced my front pads a few weeks ago. Was running Bendix Ultimates with new DBA 4000 series rotors. THe discs stayed true, plenty of dust and took out the discs to under 26mm with just one pad duration.Came across this relatively new pad from QMF called the Z8000. Put them on with cheap Protex discs.THese pads have a very high level coefficient of friction even compared to bendix ultimates cold and hot. Check out the specs on their webside.I was warned that these pads squeek and they do, but does not bother me cause they grip really well. Very dusty.If you want pads that really pull up the car with brakes cold or hot and can put up with dust and a bit of a squeek on braking these are a great pad. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m Gender: Male Location: Probably above atmospheric pressure Posted 27/08/15 10:00 AM Share Posted 27/08/15 10:00 AM (edited) QFM*Queensland Friction MaterialsMaximum temperature rating on them?Edit - 0 to 850°CCarbon Fibre Series, sounds fancyhttp://qfm.com.au/article/52/Perfomance-Series-Z88-XD88-and-Carbon-Fibre-Z8000 Edited 27/08/15 10:01 AM by -Stever- Link to comment Share on other sites More sharing options...
