Puffwagon Puff Gold Donating Members 15,123 Member For: 9y 2m 24d Gender: Male Location: South Australia Posted 10/09/17 11:26 AM Share Posted 10/09/17 11:26 AM I don't think there is a standard as such but if you have 2% or less on the trims then you're good as far as the tune goes. As far as the gauge moving give or take a point, that could be more to do with the wb feedback rate than the tune. I'd be happy if I got my car back with 2% trim and a steady wb readout. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m Gender: Male Location: Perth Posted 10/09/17 11:27 AM Author Share Posted 10/09/17 11:27 AM If your cars idling like sh*t at stoich you have a bigger issue. Have a listen to the power and speed podcast EP with Greg Banish. Lots of good info about cats and lambda. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,123 Member For: 9y 2m 24d Gender: Male Location: South Australia Posted 10/09/17 11:42 AM Share Posted 10/09/17 11:42 AM Did someone say cats? Ralph Wiggum is right about the sh*tty idle. With a good tune a car should idle smoothly at a wide range of afrs. Link to comment Share on other sites More sharing options...
Boosting_G6E Member 96 Member For: 8y 2m 2d Posted 10/09/17 11:47 AM Share Posted 10/09/17 11:47 AM exactly thanks for that guys I was thinking to much into it , oh cats what are they maybe we should start running straight dump pipe out of side fender guards Link to comment Share on other sites More sharing options...
Boosting_G6E Member 96 Member For: 8y 2m 2d Posted 11/09/17 01:07 PM Share Posted 11/09/17 01:07 PM (edited) On 10/09/2017 at 8:57 PM, Ralph Wiggum said: If your cars idling like sh*t at stoich you have a bigger issue. Have a listen to the power and speed podcast EP with Greg Banish. Lots of good info about cats and lambda. is Ralph a tuner him self just curious seems as if the guy knows his stuff and ya should idle fine from 11:1 to close 17:1 which it does, easy way I find is to block of the FPR vacuum so it raise's pressure saves jumping to tablet to edit tune whilst on the subject to form a VE table, is it true its slightly easier with a boosted application have only done a few cars in past still the same concept obviously but was a bit fiddly also in vcm suite is there a way we can go by pulse width instead of target a/f ratio if that is possible would make it 100 x easier for me Edited 11/09/17 01:13 PM by Boosting_G6E Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,298 Member For: 16y 13d Gender: Male Location: Melbourne Posted 11/09/17 01:19 PM Share Posted 11/09/17 01:19 PM Ralph is a backyard tuna. The best place to have it, too, as that farkin' smell is horrible haha. Link to comment Share on other sites More sharing options...
Boosting_G6E Member 96 Member For: 8y 2m 2d Posted 11/09/17 01:28 PM Share Posted 11/09/17 01:28 PM 6 minutes ago, k31th said: Ralph is a backyard tuna. The best place to have it, too, as that farkin' smell is horrible haha. hah who else knows this Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m Gender: Male Location: Perth Posted 11/09/17 10:09 PM Author Share Posted 11/09/17 10:09 PM (edited) On 9/11/2017 at 11:19 PM, k31th said: Ralph is a backyard tuna. Am Not, I'm either A Street Tuner A Dyno Tuner A Racetrack Tuner But never a backyard tuner as although I've got a decent size back yard, getting up to speed and stopping without hitting the fence is very difficult. Edited 11/09/17 10:25 PM by Ralph Wiggum 1 Link to comment Share on other sites More sharing options...
rollex Member 682 Member For: 9y 10m 15d Gender: Male Location: Australia Posted 11/09/17 11:08 PM Share Posted 11/09/17 11:08 PM 9 hours ago, Boosting_G6E said: is Ralph a tuner him self just curious seems as if the guy knows his stuff and ya should idle fine from 11:1 to close 17:1 which it does, easy way I find is to block of the FPR vacuum so it raise's pressure saves jumping to tablet to edit tune also in vcm suite is there a way we can go by pulse width instead of target a/f ratio if that is possible would make it 100 x easier for me Does anyone know if any return flow fords run a fuel pressure sensor? They have the maps available for the returnless setups to scale slope based on delta P across the reg, just wondering if they are ever set up to use it as compensation on a return flow system as well. Regarding target pulse width no that is not possible, these ECUs are designed to meet strict emissions and hence use a complicated speed density model to achieve this. Targetting pulse width would mean you have no scaling for temperature/humidity etc, unless of course you meant base pulse width (which is then added to). You could calculate this in excel though I'm not sure of the utility as the target pulse width is always going to be scaled and hence not what you log. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m Gender: Male Location: Perth Posted 11/09/17 11:25 PM Author Share Posted 11/09/17 11:25 PM My F6 does Rolls. But only because I've got a fuel lab pump and reg setup that varies pump speed based on return flow... The only return flow systems I've seen with FPS's are the diesel setups. Enable returnless control. We can all run mustang dual intank modules and pump controllers and get on with life. Link to comment Share on other sites More sharing options...
