Vylnt79 Member 170 Member For: 11y 10m 11d Posted 03/04/15 04:13 AM Share Posted 03/04/15 04:13 AM Hi guys Iv got 19x9.5 +40 rear staggered rims and 19x8.5 +36 fronts and was wanting to fit 285/35/19 rear and 245/35/19 front on my fg xr6t sedan I was looking at the contisportcontact5p will I have any issues or all good cheers. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 1m 6d Gender: Male Location: Perth Posted 03/04/15 04:50 AM Share Posted 03/04/15 04:50 AM Personally, I'd look at running a 255 up front if looking to run a 285 rear...will give you more balanced handling and help reduce understeer. You'll also want to run different profiles front and rear. If you're going to run a 35 profile at the front then you'll need to run a 30 profile at the back in order to keep the rolling diameters more closely matched. 285 on a +40 rear will probably rub on the guards over bumps if the car is lowered, would be close though. Link to comment Share on other sites More sharing options...
Vylnt79 Member 170 Member For: 11y 10m 11d Posted 03/04/15 06:15 AM Author Share Posted 03/04/15 06:15 AM What if I run a 40 profile up front and a 35 rear would that be ok?Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Vylnt79 Member 170 Member For: 11y 10m 11d Posted 03/04/15 06:16 AM Author Share Posted 03/04/15 06:16 AM And if lowering should I lip the guards?Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 03/04/15 07:02 AM Share Posted 03/04/15 07:02 AM Amazing tyres, have them on my gayadore. Superfungrippytime Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 1m 6d Gender: Male Location: Perth Posted 03/04/15 08:56 AM Share Posted 03/04/15 08:56 AM (edited) 40 profile up front and 35 profile at the rear would also be ok, unless you want to keep it legal...in which case, no (straight from VSB14 "The overall diameter of any tyre fitted to a passenger car or passenger car derivative must not be more than 15mm larger or 26mm smaller than that of any tyre designated by the vehicle manufacturer for that model.").Ideally you want to try keep the rolling circumferences as close as possible front to rear. Use this website as a guide:http://www.willtheyfit.com/Problem with FG's is that there isn't really any guard to roll at the rear, your paint will generally just crack unfortunately.But as WB said, they're great tyres! Edited 03/04/15 08:57 AM by .Stripes. Link to comment Share on other sites More sharing options...
