Mac0892 Member 72 Member For: 11y 6m 10d Gender: Male Location: Adelaide Posted 20/02/15 11:45 AM Share Posted 20/02/15 11:45 AM Hey guys, got a small issue I was wondering if anyone had come across at all. (BF Mk2 Turbo)basically, have had a small scraping noise from RHF wheel for a while, heard easier at higher speed or with car on hoist and spinning the wheel. even spinning the rotor and hub with the wheel off you can hear a slight scrape.At first, thought it may have been brake related, so checked over all the brakes and metal to metal contact points, nothing so far.wheel bearing has no movement. ball joints and steering rack / tie rods are sound.can drive the car for day to weeks at a time and you don't notice at all. then on the odd occasion, there is a large scraping / groaning noise from the RHF, but goes away after 10-15 seconds and wont re-appear for a while.I've tried to replicate several times on the same road, same speed etc.its there going up hills, along flats, smooth surfaces, you name it.very intermittent noise, and hard to describe it.anyone come across anything similar? almost at the point of burning it to the groundbit of extra info of setup - 19" wheels over the PBR upgraded brakes with DBA T3 rotors and a set of bendix ultimatesthanks,Mac Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 1d Gender: Male Location: Perth Posted 20/02/15 01:11 PM Share Posted 20/02/15 01:11 PM Hand brakes shoes Link to comment Share on other sites More sharing options...
Mac0892 Member 72 Member For: 11y 6m 10d Gender: Male Location: Adelaide Posted 20/02/15 02:17 PM Author Share Posted 20/02/15 02:17 PM front right though. didnt think handbrake shoes would be related. do need to re-adjust it at some stage. comes up a little high for my liking Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 1d Gender: Male Location: Perth Posted 20/02/15 02:29 PM Share Posted 20/02/15 02:29 PM Sorry, misread your post. Link to comment Share on other sites More sharing options...
kjoy064 Member 276 Member For: 17y 1m 11d Gender: Male Location: WA Posted 20/02/15 07:40 PM Share Posted 20/02/15 07:40 PM Have you looked into the front wheel bearing. Sounds similar to the front on my FG. Replaced hub assembly and I'm all good now.Again on the RHF, LHF is still perfect Link to comment Share on other sites More sharing options...
DD-XR-6T Member 134 Member For: 11y 29d Gender: Male Location: Sydney/Canberra Posted 20/02/15 08:10 PM Share Posted 20/02/15 08:10 PM +1 My RHF wheel bearing went and all the others were fine. We must take left handers at higher speeds Link to comment Share on other sites More sharing options...
Mac0892 Member 72 Member For: 11y 6m 10d Gender: Male Location: Adelaide Posted 20/02/15 11:26 PM Author Share Posted 20/02/15 11:26 PM I checked the wheel bearings maybe a month ago and they were all good. s'pose there is no harm in replacing the hub assembly to rule it out.going for a long drive later on so hopefully it will happen again Link to comment Share on other sites More sharing options...
bjc Donating Members 2,812 Member For: 20y 7m 20d Gender: Male Location: Townsville Posted 21/02/15 12:09 AM Share Posted 21/02/15 12:09 AM Drive slowly with the windows down through a new estate with bulk housing or industrial area with big concrete building to hear the reverb. You might get a better idea of what it is then?Small rock stuck somewhere? Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 15y 9m 7d Gender: Male Location: Perth, Western Australia Posted 21/02/15 05:51 AM Share Posted 21/02/15 05:51 AM (edited) The part number for the front bearing hub is AU22B663A - do a search for it on eBay for the best price.There are various aftermarket options. The really cheap ones are known for not lasting long. The Ford ones are regarded as lasting the longest.Easy to replace - photo guide: http://www.fordxr6turbo.com/forum/topic/89016-photo-essay-babf-front-bearing-hub-replacement Edited 21/02/15 05:54 AM by PhilMeUp Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 18y 11m 5d Posted 21/02/15 11:56 AM Share Posted 21/02/15 11:56 AM (edited) That sounds like your DSC is cutting in...if it feels like a vibration from the front left wheel...that's intermittent as you're driving...if your DSC is playing up it can trigger the ABS to go off on a certain wheel, as it assumes a correction is needed to stabilise the car...this can feel like a grinding vibration coming from the effected wheelThis assuming its nothing else more obviousThough after re reading your post I'm not so sure now... Edited 21/02/15 11:59 AM by boost69 Link to comment Share on other sites More sharing options...
