nathanway Member 106 Member For: 12y 8m 14d Gender: Male Location: townsville Posted 17/12/14 04:08 AM Share Posted 17/12/14 04:08 AM hello all ,after a long road ive just got the first tune on my xr complete so far its made 395.5rwkw on 98 with a easy tune running 18psinext step is to switch up to barrel e85 change the fuel reg and fuel rail and go for 430-450rwkw and go for a mid 10 passso far the car had ran a 11.8 @ 116mph (322kw) with the baby turbo with out cams or oil pump or fuel systemI raced it and ran the 11.8 only to drive back to Townsville and the stock turbo let go as we got home (thank god mackay is 4hrs away)so I race out and brought a gtx3582r and bolted it on took my rear housing to mtq and got it ported and bolted it all back together,drove it over to tms (about 1klm down the road) for a quick touch up tune to make it driveable before upgrading the fuel system to suit the bigger turbomtq stuffed up the mod and didn't install a large enough flapper and the tuner was unable to control the boost below 18psi and that's way to much air for the stock fuel system to cope withso I drove it about like a diesel only reving it to 3500rpm for like a month till I had the money to start the next round of modsabout a week before it was booked into start the mods my missus rang me up and said its making a bad noise when it revs about 2000rpm, I told her to drop it over to tms straight up and see what they thinkturns out the cam chain guides and tensioner are fok'd.than im told that to get to the bolts for the guides you need to drop the sump :/so I ended up getting it fixed and while its all apart I got the tbre oil pump with billet gears and a set of tbre stage 1 cams, along with a plasmaman surge tank with twin 044s (only running one atm with 98 tune) and a retune after a bit of trial and error the tune is good making good power with a lumpy idle ( cams ended up being much more aggressive than first thort)its been a rough ride getting it to this stage but its all done properly with just about every surport mod I could do to keep it safe at this level basically the only thing left to do is to build the motor and go a new turbo set up with boost 6 manifoldmods so far includerapid systems intercooler and pipingturbo side intake with relocated battery to oppersite side4inch exhaust turbo back1000cc id injectors38mm turbosmart bovgtx3582R turbo with mod'ed gatetbre oil pumptbre stage 1 cams (apparently equivalent to atomic stage 4)plasmaman surge with twin 044 all wired up for both only running 1 atmnew oil line with filter for the turboxcal 3adjustable suspensionmolly tale shaft built about 5 times by hardy spicer cause there spaz and couldnt get it right for some reasonnizpro build zf stage 2.5 with billet intermediate shaft good for about 600kw ( cost lots!)mt 275 street radialshoping for 10.9 with 98 and mid 10 with e85wish list for the futuretbre built motor good for 1000hp +boost 6 turbo manifoldtwin external gatesgtx45 turboat least a 9.9 sec passbut im waiting for e85 to be at the pump before I get a built motorthis not sure if I have to do the fuel rail to run e85if I should go a gtx 45 turbo or a gtx 42what 1000cc id injectors max out at and whats the next size injector I should run to go 600-700kwif I should get the crank done when I build the motorwhat the go is with the destroker kits and if its worth itany help would be great 1 Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 10y 9m 18d Gender: Male Posted 17/12/14 11:03 AM Share Posted 17/12/14 11:03 AM 1000's should see you well in to 500's on pump and prob mad at e85. KPM do a 1500 and I think a 2000 if you feel you really need them 1 Link to comment Share on other sites More sharing options...
