Gianni0991 New Member 13 Member For: 11y 6m 22d Posted 26/11/14 08:09 AM Share Posted 26/11/14 08:09 AM So the other day my stereo and ac cut out and hasn't come back on. It was originally happening intermittently where it would shut off and then come straight back. And when it came back on it would have reset itself like I had replaced the battery. Any help would be great as its driving me crazy and I live in a place that has 40 odd degree days Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 10y 11m 18d Gender: Male Location: Western Sydney Posted 26/11/14 08:33 AM Share Posted 26/11/14 08:33 AM Could be a loose plug behind or underneath the icc. Or on top if it's an FG. Link to comment Share on other sites More sharing options...
Pixy Angel Expert Donating Members 9,132 Member For: 19y 1m 24d Gender: Male Location: North Jamberoo, NSW Posted 26/11/14 09:46 AM Share Posted 26/11/14 09:46 AM Have you tired disconnecting the battery for a few minutes? Give this a go might work but I have been know to be wrong. Link to comment Share on other sites More sharing options...
Gianni0991 New Member 13 Member For: 11y 6m 22d Posted 26/11/14 12:13 PM Author Share Posted 26/11/14 12:13 PM It's a ba. Will try the trick tomorrow to see what happens otherwise I might have a look at the plugs. Cheers Link to comment Share on other sites More sharing options...
Pixy Angel Expert Donating Members 9,132 Member For: 19y 1m 24d Gender: Male Location: North Jamberoo, NSW Posted 27/11/14 08:46 PM Share Posted 27/11/14 08:46 PM How did you go is the ICC working again. Link to comment Share on other sites More sharing options...
Gianni0991 New Member 13 Member For: 11y 6m 22d Posted 28/11/14 07:31 AM Author Share Posted 28/11/14 07:31 AM Nah. Tried the battery trick. It lasted for 5 minutes and then shut down again. Going to try n check the connections this weekend. Here's hoping the module isn't dieing/dead Link to comment Share on other sites More sharing options...
Gianni0991 New Member 13 Member For: 11y 6m 22d Posted 29/11/14 10:22 PM Author Share Posted 29/11/14 10:22 PM So I pulled the whole icc unit out. Couldn't find anything to major. Only thing I can put it down to is the main plug to the back of the icc was a bit loose and maybe it was connected up properly. It's working fine for now. Will just have to wait and see if it's good or wants to play up 1 Link to comment Share on other sites More sharing options...
Gianni0991 New Member 13 Member For: 11y 6m 22d Posted 08/12/14 12:20 PM Author Share Posted 08/12/14 12:20 PM (edited) So after a week the system has died agian. Cant get it to reboot this time. Pulled console out again same as last time. Still will not start up. Anyone got any ideas? Edited 08/12/14 12:21 PM by Gianni0991 Link to comment Share on other sites More sharing options...
xr6tForMe Donating Members 205 Member For: 10y 9m 21d Gender: Male Posted 11/12/14 09:37 PM Share Posted 11/12/14 09:37 PM Have you checked fuses? Have you checked that the power supply wire is providing power? If those things look ok, it would seem to be the ICC itself. If it was me I would see if I can pull the unit apart to look if anything electrical looks burnt or corroded, or bulging/leaking capacitors or a fuse inside it which has blown.I suppose it could also be something that the ICC is connected to that causes a problem (en. shorted out speaker wires, or a fault with the AC).Does it turn on if you just connect power to the right wires and nothing else connected? Link to comment Share on other sites More sharing options...
Gianni0991 New Member 13 Member For: 11y 6m 22d Posted 21/12/14 01:20 AM Author Share Posted 21/12/14 01:20 AM Yeah I'v checked all your main fuses. Going around a mates place to pull it apart and see what we can find. Will update when I find something Link to comment Share on other sites More sharing options...
