jwill_baturbo Member 2 Member For: 9y 4m 24d Posted 25/11/14 11:24 PM Share Posted 25/11/14 11:24 PM Hey guys, need advice.My xr6t has a regular misfire. I have checked cool packs and they seem to be fine. Replaced spark plugs to be careful.Also the car is sitting at a 2200 resting rpm both when it's hot and cold. When I put the clutch in to change gears or when I am powering down for traffic the revs spike to 4000rpm and do not reduce until the car has come to a complete stop. Furthermore I can now drive around the city without using my accelerator as the idle is rising of its own accord. If I coast while in gear the revs will slowly climb and force the speed to increase.There is a distinct fuel smell associated with the issue, causing the car to have an average fuel economy of 30l/100kmAny help would be appreciated!!Thanks, Josh Link to comment Share on other sites More sharing options...
rapid6turbo Member 56 Member For: 10y 11m 24d Gender: Male Posted 25/11/14 11:34 PM Share Posted 25/11/14 11:34 PM Try giving the throttle body a clean, maybe the idle air control is all blocked up. Any fault codes? Link to comment Share on other sites More sharing options...
jwill_baturbo Member 2 Member For: 9y 4m 24d Posted 25/11/14 11:52 PM Author Share Posted 25/11/14 11:52 PM I haven't had the time or money to get an error code check. But I am concerned that it may be a vacuum leak. There is a lot more noise in the engine bay than usual, but I am not sure if it is just because the higher rev.Will try cleaning the t/body and hopefully that works. The car is becoming dangerous to drive, as I have to consistently brake to compensate for the idle increase Link to comment Share on other sites More sharing options...
xr6tForMe Donating Members 205 Member For: 10y 9m 21d Gender: Male Posted 26/11/14 11:02 AM Share Posted 26/11/14 11:02 AM I think this might be a vacuum leak somewhere between the throttle body and the head. I had an intake manifold gasket fail on an AU Falcon and the idle was high. I found it by connecting a thin hose from a can of butane (for a camping stove - or a lighter refill can would do) and spraying around the manifold until the idle changed. The hose allowed the gas to be well targetted. When the gas was sucked into the engine instead of just extra air, the idle changed.I have heard of other things than gas being used, but that seemed the best idea to me.Look/listen for a leak and try the gas idea. Be careful to do it outside so everything is well ventilated and do not set everything on fire! Link to comment Share on other sites More sharing options...
BRK Member 361 Member For: 12y 4m 6d Gender: Male Location: Perth Posted 26/11/14 12:02 PM Share Posted 26/11/14 12:02 PM You can use carby cleaner or wd 40 as well. Agree that this sounds like a big time air leak. Link to comment Share on other sites More sharing options...
Damon1996 New Member 3 Member For: 6y 3m 4d Posted 15/01/18 10:22 AM Share Posted 15/01/18 10:22 AM Didn’t want to make a new post because there is probably heaps out there, new to the whole xr6t game but here’s my problem. Put new plugs in couple of weeks ago few days later car misfiring like a *beep*, replaced all the coil packs and it seems to be only on cylinder5 that has the miss, no matter what coil I put in still on 5, did a comp test and come up with pretty good numbers, my question is does anyone know of anything that could be the problem and are the idrium plugs a waste of time and money? What’s the best plug to run as I’m thinking this could be the problem but I’m unsure!!? any help is appreciated thanks Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,116 Member For: 9y 2m 20d Gender: Male Location: South Australia Posted 15/01/18 11:07 AM Share Posted 15/01/18 11:07 AM Is the plug fouled? Is the plug gap ok? Are they genuine coils? Is the injector injectoring? Is the coil sparking? That's just stuff to check. The general consensus around here is to buy gas motor plugs from ebay for $50 or so. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,291 Member For: 16y 9d Gender: Male Location: Melbourne Posted 15/01/18 11:08 AM Share Posted 15/01/18 11:08 AM BKR6EIX are great for these cars and come with the right gap for a tuned car. If you don't want to use iridiums again, then just get them from Ford. If you have a miss specifically on one cylinder, then it'd be worth swapping around coils and plugs to if it follows any specific hardware. 1 Link to comment Share on other sites More sharing options...
