Jezzza404 Member 3 Member For: 9y 6m 7d Posted 31/10/14 12:27 AM Share Posted 31/10/14 12:27 AM Hey guys,I just got my rear bushes replaced for my diffNow when I apply brake pressure (and hold from 70 to 20 kph), there is a creaking noise and when I let go there is a clunk noise. Even going slow speeds the creak noise is loud, and the clunk is still thereIf I brake very slowly and steadily down to 0, and slowly release my foot, there is no clunk..It only sounds like it is coming from the rear right drivers sideIt also has a burning smell like clutch/handbrake on all the timeSounds like my rear caliper is loose?Ive had a look under the car, and it appears the rear centre has been changed to a polyurethane bush, but cant tell what the side ones areI dont suspect its the bushingsAnyone know?I have told the shop, they said to bring it in. They said they will look at itThe noise wasnt there before, just hope they dont try to shaft me! Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 1m 7d Gender: Male Location: Perth Posted 31/10/14 12:46 AM Share Posted 31/10/14 12:46 AM Poly bushes generally introduce more noise. Clunking in usually one of the symptoms. You should ask them what bushes they fitted (I.e. what brand and model) as some transmit more noise than others. Link to comment Share on other sites More sharing options...
Jezzza404 Member 3 Member For: 9y 6m 7d Posted 31/10/14 12:53 AM Author Share Posted 31/10/14 12:53 AM (edited) Thanks for replyI read the how to change diff bushes, doesnt appear you need to fiddle with brake calipers at allIt only happens when I brake though, and it did start to have a burning smellSo I suspect its more than just bushes wearing in?edit: Ill also add, that my gearbox and tailshaft just got done too, its about 50kms old!The noise was definately not there before my diff bushes got done Edited 31/10/14 12:59 AM by Jezzza404 Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 1m 7d Gender: Male Location: Perth Posted 31/10/14 01:04 AM Share Posted 31/10/14 01:04 AM Yep, like I said, poly diff bushes tend to transmit more NVH than the factory rubber bushes. If you can find out which bushes were fitted we'll be able to tell you a bit more. Link to comment Share on other sites More sharing options...
bluey360 Member 2 Member For: 9y 3m 10d Posted 12/01/15 04:10 PM Share Posted 12/01/15 04:10 PM Dont assume anything , dont take anything for granted Link to comment Share on other sites More sharing options...
