coolfgxr6t Member 30 Member For: 10y 7m 23d Posted 27/08/14 12:08 AM Share Posted 27/08/14 12:08 AM Hey guys. I have lost power steering. It still works if I rev it over about 2g. It also makes a loud whine sort of like a super charger haha. Is this problem common? My car runs out of warrenty in couple weeks do you think it could be replaced under warrenty? Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 18y 11m 6d Posted 27/08/14 12:22 AM Share Posted 27/08/14 12:22 AM Yeah they should replace the pump under warranty.Though usually it's one of the power steering hoses that leaks at the connector.I had to replace mine once on the BF when it was out of warranty, and the genuine power steering hoses cost more than the power steering pump. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 7m 1d Gender: Male Location: Perth Posted 27/08/14 12:29 AM Share Posted 27/08/14 12:29 AM Fluid level? Link to comment Share on other sites More sharing options...
coolfgxr6t Member 30 Member For: 10y 7m 23d Posted 27/08/14 12:37 AM Author Share Posted 27/08/14 12:37 AM fluid is full. just whines real bad and no steering when revs are low. Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 18y 11m 6d Posted 27/08/14 01:03 AM Share Posted 27/08/14 01:03 AM If it does leak you will see it dripping onto the alternator usually...If no leak, then it probably is the pump or even an issue with the belt or pulley... Link to comment Share on other sites More sharing options...
coolfgxr6t Member 30 Member For: 10y 7m 23d Posted 27/08/14 02:34 AM Author Share Posted 27/08/14 02:34 AM Yeah no leaking or anything. belt and pully seem to be fine. Not loose or anything and its turning the pully ok. mainly just wanted to check if it could be a warrenty fix because if its not if rather fix it myself and not have ford rip me off. Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 18y 11m 6d Posted 27/08/14 04:12 AM Share Posted 27/08/14 04:12 AM If your car has warranty, then there should be no issue at all. Link to comment Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 13y 3m 16d Gender: Male Posted 27/08/14 11:12 AM Share Posted 27/08/14 11:12 AM (edited) Had this happen to me recently, got the fluid flushed and it's been fine, power steering fluid isn't in any service schedule.edit: for info my car is 4.5 yrs old and has seen a bit of opposite lock, the guys at the power steering place said the fluid was black, I had only asked fraud a month earlier to check it and they said it was fine.... Edited 27/08/14 11:14 AM by Bulletime Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m Gender: Male Location: Probably above atmospheric pressure Posted 27/08/14 01:44 PM Share Posted 27/08/14 01:44 PM Really should do mine...have never flushed it... Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 5m Gender: Male Location: Probably above atmospheric pressure Posted 20/05/16 06:01 AM Share Posted 20/05/16 06:01 AM Well look what I found...thread mine! My power steering pump has started to die 2 years later - but I did change the fluid a couple of times in between...I put it down to the 303,000km on the thing. Link to comment Share on other sites More sharing options...
