JimmyRickard Member 18 Member For: 10y 7m 22d Posted 26/06/14 01:40 AM Share Posted 26/06/14 01:40 AM Hi guys, I recently bought some new tyres for my F6 and they are tripping out the ABS & traction control, and also causing a brake failure signal. I took it to Ford Service and was told it was an issue with the size tyres I am using due to the rolling circumference messing with the computer, as they put a set of stockies on which worked fine. I bought the car secondhand with staggered enkei wheels, which I believe are 19x11 in the rear and 19x8 (?) in the front. Not entirely sure what the size of the wheels are, but the tyres which the car came with were 275/30 in the rear and 245/35 in the front. I got a set of 285/35's put on the rear as the 275's were stretched, which appears to have caused the issue as I haven't changed the fronts to match. Would putting 40 series tyres on the front fix the problem? I don't want to pay for another set of tyres and have the same issue. Is there a way to calculate this or something? Cheers Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 26/06/14 01:58 AM Share Posted 26/06/14 01:58 AM (edited) Should do 285/30/19 is 655mmOD 285/35 is 683mmOD245/35/19 is 655mmOD and 245/40 is 679mmODAt the moment you have a height difference of 28mm. If you go 245/40 it will only be 4mm.I gather your car is FG Edited 26/06/14 02:01 AM by arronm Link to comment Share on other sites More sharing options...
JimmyRickard Member 18 Member For: 10y 7m 22d Posted 26/06/14 02:07 AM Author Share Posted 26/06/14 02:07 AM Sorry yes it's an FG. will 245/40/19 fit on the front? will it fix the issue? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 1d Gender: Male Location: Perth Posted 26/06/14 02:13 AM Share Posted 26/06/14 02:13 AM Yes and 99% it will fix the issue 1 Link to comment Share on other sites More sharing options...
JimmyRickard Member 18 Member For: 10y 7m 22d Posted 26/06/14 03:03 AM Author Share Posted 26/06/14 03:03 AM OK great thank you Link to comment Share on other sites More sharing options...
