VippiN Member 94 Member For: 15y 3m 16d Gender: Male Location: Adelaide, Australia Posted 21/04/14 05:01 AM Share Posted 21/04/14 05:01 AM Hey guys. What do you use for sectioning off the tray for carrying smaller goods? For example if you wanted to section off three parts of the tray. Often I'm carrying a lot of heavier smaller gear than larger items. A rubber tray liner won't cut it. Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 3m 5d Gender: Male Location: Christchurch, New Zealand Posted 21/04/14 05:34 AM Share Posted 21/04/14 05:34 AM The standard liner has slots that you can put 8 by 2 in cut to the right dimensions. The owners manual even has the dimensions in it. 1 Link to comment Share on other sites More sharing options...
wateva526 Member 30 Member For: 10y 9m 2d Gender: Male Location: Sydney Posted 10/06/14 06:31 AM Share Posted 10/06/14 06:31 AM I made mine cheaply and was easy to get(leftovers from work) made from mdf and a bit of framing at the bottom of it to stop it wobbling around. It sits 290mm high (width of the mdf I used). Unfortunately I cant post photos to show what I mean Link to comment Share on other sites More sharing options...
vrmmmpshhh Inactive Members 1 Member For: 9y 7m 19d Posted 17/09/14 11:28 PM Share Posted 17/09/14 11:28 PM I got a really big cardboard box and laid it out on the tray then I got hard cardboard corners that warehouses use to tape pallets together and glued them down as partitions. If I need to carry big stuff I just take the cardboard out. Link to comment Share on other sites More sharing options...
shredder New Member 15 Member For: 11y 1m 21d Posted 18/10/14 11:28 AM Share Posted 18/10/14 11:28 AM (edited) 200 x 75 treated pine sleeper cut to length with a little sanding on the edges with a flapper wheelcovered with marine carpet works for me. CheapAd's a little weight to the tail to & comes out in 1 piece. if short bits cut the same it can double as a little bench seat .If you installed a front one as well long flat loads wider than the wheel tubs can now go over top of tubs. Edited 18/10/14 11:29 AM by shredder 2 Link to comment Share on other sites More sharing options...
