genx2g Member 95 Member For: 10y 5m 28d Posted 05/02/14 10:30 AM Share Posted 05/02/14 10:30 AM all of a sudden my car has a red hand symbol pop up on the dash and wont let me lock or unlock my car?Can anyone please explain this to me Link to comment Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 21y 5m 4d Gender: Male Location: Dé·jà vu Posted 05/02/14 10:50 AM Share Posted 05/02/14 10:50 AM Did it also lock the glovebox?... Link to comment Share on other sites More sharing options...
genx2g Member 95 Member For: 10y 5m 28d Posted 05/02/14 10:57 AM Author Share Posted 05/02/14 10:57 AM is that a serious question? if so, I dont know didnt check. Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 10y 8m 12d Gender: Male Location: Adelaide Posted 05/02/14 11:11 AM Share Posted 05/02/14 11:11 AM ^^^ good one dags.<br />have a look in your fraud manual Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 1m 24d Gender: Male Location: Frankston, 3199 Posted 05/02/14 11:16 AM Share Posted 05/02/14 11:16 AM Immobilizer - am sure there was a thread about the same issue in the last week or so. Will try and find it Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 1m 24d Gender: Male Location: Frankston, 3199 Posted 05/02/14 11:23 AM Share Posted 05/02/14 11:23 AM Can't find anything - might have been another forum. I think battery charge was a thing to check Link to comment Share on other sites More sharing options...
Adran Member 38 Member For: 10y 6m 21d Posted 05/02/14 11:26 AM Share Posted 05/02/14 11:26 AM I had this problem in my au ute which has something to do with the old au keys where the battery in the key will drain to a level it does not deactivate the car immobiliser... Hope this helps Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 16y 11m 24d Gender: Male Location: ACT Posted 05/02/14 10:47 PM Share Posted 05/02/14 10:47 PM This light is the security indicator & is activated for 3 seconds when the ignition is first turned to the ON position. The security indicator is continually flashed when the ignition is turned to the OFF position.If the Security Indicator is always on and you can't start the car then the PCM (powertrain control module - main computer) and/or the BEM (body electronics module) has engaged the security system.This is caused by a system malfunction. The system is quite complex and has many sensors and switches (called inputs) that could be the cause.The next step is to have a Multifunction Output Test done to see what's causing the fault.This is best done by your local Ford dealer as they have the correct tool to do it - called a WDS (worldwide diagnostic system).Unfortunately there is nothing that you can do at home to rectify this.From:http://www.justanswer.com/ford/6n8tw-ford-falcon-warning-light-shape-human-hand-lit.html 1 Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 16y 11m 24d Gender: Male Location: ACT Posted 05/02/14 11:24 PM Share Posted 05/02/14 11:24 PM (edited) Also... have you checked the battery in your: Edited 05/02/14 11:27 PM by f-wolf Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 1m 24d Gender: Male Location: Frankston, 3199 Posted 05/02/14 11:36 PM Share Posted 05/02/14 11:36 PM Haven't changed anything recently, pugged anything new in?You were having similar troubles when you plugged in an OBDII?Have heard with other vehicles that the system can do a random check of the system components - someone can change a head unit, seat etc and car works fine for a while - until the system check randomly queries the item that was changed. Then it kicks up the error. Link to comment Share on other sites More sharing options...
