Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 27d Gender: Male Location: Perth Posted 27/06/17 10:09 AM Share Posted 27/06/17 10:09 AM Pics? Link to comment Share on other sites More sharing options...
samhouston Donating Members 153 Member For: 14y 11m 11d Gender: Male Location: Brisbane Posted 27/06/17 12:16 PM Share Posted 27/06/17 12:16 PM I have gone to a bit of a frankenstein setup but it seems to work ok. Ditched the ARP bolts and gone to 12.9 socket cap bolts with Atomic washers 3x 11mm dowels, welded to the flywheel. Bolts tightened to 90ft/lbs Made up a plate with 6 holes in it which fits over the bolts and then welded each of the bolts to the plate. Next crank I put in it, I will be looking at running 12 bolts. 1 Link to comment Share on other sites More sharing options...
Anthonyfgxr6tute New Member 2 Member For: 6y 9m 23d Posted 27/06/17 02:18 PM Share Posted 27/06/17 02:18 PM Yeah no worries. If the welded flywheel bolts are still all good what could be causing the damage to the clutch then?I've tryd 2 ace clutchs plus 1 other brand which I can't remember at moment & still has the same problem.When there fitted they feel fine but after being on the dyno & driven for a few weeks it develops a shutter & is hard to get into 1st & reverse.Don't really want to go & weld the bolts in on the new set up untill I know whats causing it & fix it. Link to comment Share on other sites More sharing options...
samhouston Donating Members 153 Member For: 14y 11m 11d Gender: Male Location: Brisbane Posted 28/06/17 01:14 AM Share Posted 28/06/17 01:14 AM What sort of damage is being done to the clutch? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 28/06/17 06:33 AM Share Posted 28/06/17 06:33 AM (edited) 12.9 don't like to be welded with no preheat. May hold. The hardness of 12.9 also makes them subseptable to hydrogen embrittlement what you have done sounds good in the theory . But I would say they will crack at the welds. Edited 28/06/17 06:33 AM by arronm Link to comment Share on other sites More sharing options...
samhouston Donating Members 153 Member For: 14y 11m 11d Gender: Male Location: Brisbane Posted 28/06/17 07:13 AM Share Posted 28/06/17 07:13 AM I was skeptical as I thought you could get nothing better than ARP, but 4 sets of ARP later and the 12.9s are holding on a lot better. I have broken one bolt but I don't think there is much I can do with the brinelling on the crank and the lack of surface to mount to. The crank will have to come out and be repaired at some stage but until then I'm happy pulling the box out every couple of months! Link to comment Share on other sites More sharing options...
