abzy Member 8 Member For: 15y 5d Posted 03/01/13 09:30 AM Share Posted 03/01/13 09:30 AM hey, whats the best way too add an amp and sub too the fg? after all the different options cheap too expensive. I really like my quality sound so speakers will be going in eventually aswell with an amp but for now I have the amp and sub from my old ute.cheers abzy Link to comment Share on other sites More sharing options...
ledoff Member 62 Member For: 11y 3m 20d Gender: Male Posted 03/01/13 10:22 PM Share Posted 03/01/13 10:22 PM save up and do it all at the same time, it will be cheaper in the long run. just spend the extra couple of hundred and do it all at once. Link to comment Share on other sites More sharing options...
abzy Member 8 Member For: 15y 5d Posted 05/01/13 09:16 AM Author Share Posted 05/01/13 09:16 AM thanks, but I do all my stereo work myself so will be no extra cost, just time.anyone got any options? Link to comment Share on other sites More sharing options...
old_mate Member 767 Member For: 18y 2m 6d Gender: Male Location: Brisbane Posted 05/01/13 09:41 AM Share Posted 05/01/13 09:41 AM Right, if you want to use factory stereo, you need a high level converter (preferrably a processor) to get your RCA connections.Be wary though - a lot of the time, these things have issues with induced noise. The factory ford head unit is pretty sh*thouse to begin with for SQ, some people retain them for their wheel control/bluetooth/ipod interfacing.The other, (and IMO better) way is to run a traditional seperate head unit and just put up with it's lack of integration. Link to comment Share on other sites More sharing options...
#96 Member 281 Member For: 11y 4m 25d Posted 05/01/13 11:36 AM Share Posted 05/01/13 11:36 AM Right, if you want to use factory stereo, you need a high level converter (preferrably a processor) to get your RCA connections..this part I never understand... almost all amps have 'high level' inputs, capable of accepting the speaker wire and boosting the signal.the converter uses this speaker signal to begin with (ie it is not a true pre amped signal) and reduces it (unless ive missed something)what is the bennifit?(looking to do this in my car, and its one that has me stumped) Link to comment Share on other sites More sharing options...
old_mate Member 767 Member For: 18y 2m 6d Gender: Male Location: Brisbane Posted 05/01/13 11:55 AM Share Posted 05/01/13 11:55 AM noise.proper line converters and processors are balanced, the high level inputs on amps are one big source of potential problems.Without getting toooo technicial, basically as I said before the factory ford head units are sh*t. By amplifying an already sh*t signal, your basically just amplifying sh*t.A processor does as it suggests, takes the signal and does it's best to filter out the sh*t ready for amplification.Google is your friend on this. And be aware - you always get what you pay for (some of the cheaper high/low level converters and processors are sh*t) 2 Link to comment Share on other sites More sharing options...
PLAYRZ Donating Members 333 Member For: 19y 2m 12d Gender: Male Location: VIC Posted 05/01/13 11:07 PM Share Posted 05/01/13 11:07 PM As old_mate said, the signal from the Ford ICC is garbage.. I used an LLC and processor to try and reduce the signal noise further, works well but still not great. If you just want to add an entry level amp and sub then one with high level inputs should be fine for just the sub. Would suggest something better if your planning on replacing the whole system. Link to comment Share on other sites More sharing options...
Mr_xr6_Turbo1 Member 57 Member For: 13y 6m 5d Posted 06/01/13 05:02 AM Share Posted 06/01/13 05:02 AM (edited) just buy an alpine h800 and run everything from there I was running a Alpine H800 before I charged to the pioneer p99rs and I had almost no signal nosie even at high volumes Edited 06/01/13 05:03 AM by Mr_xr6_Turbo1 Link to comment Share on other sites More sharing options...
Upinder Member 114 Member For: 11y 7m 25d Posted 06/01/13 01:15 PM Share Posted 06/01/13 01:15 PM alpine h800 is the way to go if u have the money u need to get the rux control too this is what I have in my fgfocal splits frontfocal coaxal at back2 type r subs pdx v9 amppdx m12 amph800 amp runs like dream but has to be tuned the right way or u will blow your speakers up head unit would cost cheaper and u will get better sound tbh Link to comment Share on other sites More sharing options...
abzy Member 8 Member For: 15y 5d Posted 09/01/13 06:51 AM Author Share Posted 09/01/13 06:51 AM cheers for all the help!!! when I had my BA I ran a separate headunit and it was much better but this time I wanna run it through the standard, mainly due too wanting it too stay stock looking. I would say I will upgrade the speakers at the same time so I would be running my 12" type s (all the subs ive owned ive liked this the best for my tastes) that will be running off its own amp and then id go type r splits (again have been my choice due how they sound) and run them off a amp aswell. rears I usually leave stock just as rear fill as I dont really like too much sound coming from behind me.so by the sounds of it that alpine h800 sounds too be the go? whats the vehcile hub pro like? im willing too spend the extra on something good, worth doing, worth doing well I say.cheers again for the help, much appriciated Link to comment Share on other sites More sharing options...
