nxr06 Donating Members 117 Member For: 19y 11m 23d Posted 04/12/12 08:38 PM Share Posted 04/12/12 08:38 PM the MAP sensor was reading 150kpa lol which worked out to be about 27psi but it was only running on 13 Is 150kpa the reading after 98kpa is subtracted from from the value in the log?I would be very surprised if its mechanical causing this. Have you tried tuning it with waste-gate open loop? Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 12y 8m 23d Gender: Male Posted 04/12/12 08:48 PM Share Posted 04/12/12 08:48 PM Ahhh thank god someone mentioned atmospheric pressure Link to comment Share on other sites More sharing options...
nxr06 Donating Members 117 Member For: 19y 11m 23d Posted 04/12/12 09:05 PM Share Posted 04/12/12 09:05 PM Just realized you have a high-flow cat fitted. Definetly recommend getting a 12lb actuator fitted then retune. Very hard for stock actuator to behave with the mods you have and boost your intending to run....Its a juggle to get the desired boost table & wastegate duty cycle correct when high flow or knocked out cats fitted on cars with stock actuators.... I know its posted above but SCT can turn that code off, but you will find trying to tune in closed loop boost control with your setup is a struggle... Link to comment Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 12y 8m 23d Gender: Male Posted 04/12/12 09:19 PM Share Posted 04/12/12 09:19 PM Vcm can also turn the code off! Link to comment Share on other sites More sharing options...
gmhkla Donating Members 45 Member For: 13y 11m 10d Gender: Male Location: Hoppers Crossing Posted 07/12/12 08:20 AM Author Share Posted 07/12/12 08:20 AM So after all that it was a faulty map sensor.Changed the wastegate actuator, boost solenoid and bov while I was at it.No more overboost codes thank godFitted a BF 2 bar MAP sensor 1 Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 15y 10m 19d Gender: Male Location: Adelaide Posted 07/12/12 10:33 AM Share Posted 07/12/12 10:33 AM 2 bar ? Sure ? Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 20d Gender: Male Posted 07/12/12 12:07 PM Share Posted 07/12/12 12:07 PM Good on ya. Part substitution is sometimes the best way to solve problems. Link to comment Share on other sites More sharing options...
F1PERFORMANCE Donating Members 104 Member For: 15y 1m 6d Gender: Male Location: VIC Posted 07/12/12 12:49 PM Share Posted 07/12/12 12:49 PM (edited) test dont guess it will always be cheaper!! Edited 07/12/12 12:50 PM by F1PERFORMANCE Link to comment Share on other sites More sharing options...
gmhkla Donating Members 45 Member For: 13y 11m 10d Gender: Male Location: Hoppers Crossing Posted 07/12/12 01:27 PM Author Share Posted 07/12/12 01:27 PM That's what it was listed as. I'll give ya the part number sus it out I had to chop the plug n fit a new one.Also the engine light has come on again lost boost twice tonight when outside air.temp dropped as usual. Iv noticed with the bov it boosts to 1bar too but when I put the stock one on its back to 13psi0 281 002 514 it's a Bosch one. Seriously need to sort this thing out. Sho else tunes with vcm im not interested in the SCT had it before n wasn't happy with it. Each to there own.With the bov. Does any one even run aftermarket ones. Or just leave the stock one or block it all off n dw about it??? Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 13y 3m Posted 07/12/12 01:59 PM Share Posted 07/12/12 01:59 PM Sct has more parameters unlocked than vcm. Sct is better than vcm. I personally don't think your tune is at fault though. Link to comment Share on other sites More sharing options...
