Lazz1007 New Member 12 Member For: 12y 5m 12d Gender: Male Location: Perth Posted 10/01/13 04:25 PM Share Posted 10/01/13 04:25 PM :O is it safe to push the stock snail to 325rwkw? If it ever goes bust, pretty sure you've already got all the mods in place and just need to stick in a bigger turbo.anyone know the max rwkw the twin2.5 xforce can handle?Yeah mate, Im pushing 330 onmy Fg with 12pd actuator. Ive got a Manta dump and cat with the 2.5 twin xforce cat back and it handles it fine. Link to comment Share on other sites More sharing options...
Donkson Member 29 Member For: 12y 3m 25d Posted 15/12/13 05:41 AM Share Posted 15/12/13 05:41 AM Spiro Autotech Engineering quote for my fg f6The stage 1 plus kit is a tune using the flash 3 unit and a high flow cat and 4 inch dump pipe. This kit will increase the power up to 330kw. The cost to do the stage 1 plus is $2790.The stage 2 kit is one of our most popular packages. The stage two kit consists of a cold air intake, 6 x high flow injectors, a full turbo back stainless steel exhaust and custom tuned with the sct flash 3 box. This kit will increase the power to $350 - 360kw. The cost of the Phase 2 kit supplied and fitted is $4995.The stage 3 kit is a follow on from the stage 2 kit. We add an intercooler and piping kit. A Battery relocation kit. We also move the air intake from the passenger side to the driver's side. We also fit a high flow in tank fuel pump. The last up grade in our stage 3 kit is the removal of the turbo and porting the waste gate port and the replacement of the actuator to a 12psi actuator. The cost to do this is $9830. If you already have the stage 2 kit it will cost $5600 All of the above kits include custom tuning on the dyno with before and after power figures. All of the above kits will improve drive ability, throttle response and in many cases also improve fuel economy depending on driver habit.We can also go further if you are interested in more power. Please do not hesitate to contact me for further information at your convenience Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,980 Member For: 11y 1m 3d Gender: Male Location: Frankston, 3199 Posted 15/12/13 06:36 AM Share Posted 15/12/13 06:36 AM (edited) That'll be engine KW's, not rear wheel? Edited 15/12/13 06:37 AM by raband Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 9d Gender: Male Location: Vic Posted 15/12/13 09:38 AM Share Posted 15/12/13 09:38 AM $6k but you won't make 325 any other way...cough e85 Link to comment Share on other sites More sharing options...
pac23 Member 103 Member For: 11y 11m 2d Gender: Male Location: Sydney Posted 19/12/13 12:01 PM Author Share Posted 19/12/13 12:01 PM I'm pretty sure by the time you go bigger injectors and fuel system to support e85 you would be looking at 6k with a few other mods...Just saying.. Link to comment Share on other sites More sharing options...
