sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 14y 5m 24d Gender: Male Location: Far north queensland Posted 16/02/12 09:37 PM Share Posted 16/02/12 09:37 PM did you check the flywheel? Link to comment Share on other sites More sharing options...
dule Donating Members 1,180 Member For: 17y 3d Gender: Male Location: Sydney Posted 16/02/12 11:26 PM Share Posted 16/02/12 11:26 PM I'm with sex panda, check the flywheel and everything else in there. A friend had a smiliar issue on an RB25 but ONLY with the clutch in, turned out to be a missing berring of some sort some dumb f*ck performance shop owner left out when doing an engine swap. His shuddering started a lot earlier too... Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 23d Gender: Male Location: Perth Posted 16/02/12 11:49 PM Share Posted 16/02/12 11:49 PM Loose flywheel.Check the harmonic balancer as well , even thought that should cause vibration 3 -4 k , its worth checking. Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 14y 5m 24d Gender: Male Location: Far north queensland Posted 17/02/12 01:19 AM Share Posted 17/02/12 01:19 AM ^ what he said . . . again.time to start pulling sh!t apart and having a look Link to comment Share on other sites More sharing options...
Farkwiz Member 6 Member For: 15y 9m 12d Gender: Male Location: Mackay Posted 05/03/12 03:35 AM Author Share Posted 05/03/12 03:35 AM Hey guys thanks for your help. I wanted to fix this one myself but it got the better of me lol. So I took it to Direct Clutch Services in Albony, Brisbane. They were a great help as I was not an easy customer (being short on time as I traveled from Mackay to Brisbane and need to be back home in time for work) It turns out the pressure plate was broken and holding the clutch in (shifting issues, it was a wonder the fiber plate was not distroyed lol) and because I have a XR8 6 speed gear box (which I did not know about) which means it needs an adaptor (spigot bearing) for the input shaft as xr6T is 27 splin and xr8 is 11 I think. So the spigot bearing adaptor had about 1mm of play which was what was giving me the shudder. Its all good now. Thanks again to Direct Clutch Services for doing such a great help Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 4m 1d Gender: Male Location: North West Hot Hell,VIC Posted 05/03/12 07:45 PM Share Posted 05/03/12 07:45 PM Good to hear its all sorted. Bet your glad you took it there instead of having a crack at it yourself now. Link to comment Share on other sites More sharing options...
