fpr000 Member 107 Member For: 15y 12d Posted 05/11/11 09:40 AM Share Posted 05/11/11 09:40 AM this is starting to sh*t me off, ive taking the valve cover off and checked OCV's and valves etc and all looks fine, the chain is tensioned and no marks at all, and guides are fine???????????? wtf Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 17y 10m 23d Gender: Male Location: @ my laptop Posted 06/11/11 12:11 AM Share Posted 06/11/11 12:11 AM recheck the cam timing, we have seen this code quite a few times and normally the cams are out 1 tooth, normally caused by a broken guide, the plastic breaks off the top of the moving guide and falls into the crank gear and causes the chain to jump. Link to comment Share on other sites More sharing options...
fpr000 Member 107 Member For: 15y 12d Posted 06/11/11 09:35 AM Author Share Posted 06/11/11 09:35 AM Nope!! Checked everything the cam gears are in line and everything, if I up the ignition by 1 degree it stops it??? Again wtf Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 4m 1d Gender: Male Location: North West Hot Hell,VIC Posted 06/11/11 03:12 PM Share Posted 06/11/11 03:12 PM Are they factory cams or have they been replaced? Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 13y 3m Posted 06/11/11 10:29 PM Share Posted 06/11/11 10:29 PM Can you datalog Your cams on an xcal for us? Log duty cycle etc. Might give a clue. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 17y 10m 23d Gender: Male Location: @ my laptop Posted 06/11/11 11:32 PM Share Posted 06/11/11 11:32 PM log camshaft error Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 13y 3m Posted 07/11/11 12:52 AM Share Posted 07/11/11 12:52 AM What's acceptable Mick? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 17y 10m 23d Gender: Male Location: @ my laptop Posted 07/11/11 02:31 AM Share Posted 07/11/11 02:31 AM It varies all the time as per any closed loop operating system, but have seen approx 15-16 degrees error when it has jumped a tooth.It appears 15 degrees does not set the code and light but approx 16 does, well that's we saw a few weeks ago with one. Link to comment Share on other sites More sharing options...
neil101 Donating Members 123 Member For: 18y 6m 7d Gender: Male Location: Kurrajong Heights NSW Posted 12/11/11 12:10 PM Share Posted 12/11/11 12:10 PM check the ohm resistance on your cmp sensors should be between 280-380ohm could just be a sensor fault had that on a lpg ute last week and I check valve timing ocv and vct actuators ended up being a exhaust cmp sensor mine was bank1 (intake cam) p1381 and p1340 were my codes.You have rough idle and surging on cruise and full throttle?Cheers neil Link to comment Share on other sites More sharing options...
shunter22 New Member 6 Member For: 7y 10m 13d Posted 20/10/16 03:08 PM Share Posted 20/10/16 03:08 PM (edited) Thread revival! I too am having this problem, I'm getting p1381 and P1386. ( bank 1 & bank 2) I have removed the cam cover and inspected the timing chain, all of the guides are fine, and the chain looks fine. I used a screwdriver and got one more click out of the tensioner but that hasn't seemed to help. has anyone else had these symptoms? I'm thinking I might remove the cam cover garnish and check the resistance on the sensor next, any other suggestions? Edited 20/10/16 03:09 PM by shunter22 Spelling Link to comment Share on other sites More sharing options...
