Welcome to Ford XR6 Turbo.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Sign in to follow this
Followers 0
Sh00tme!
Rear Wheel Bearings On A Ba
Hi Guys,
Over the past 2 weeks or so I've noticed a humming from the rear of my 03BA (under load while cornering), after a quick call into fraud they informed me that it was the rear wheel bearings and that they need replacing.... @ $598 a side :censored:
After a quick session on Google and asking a mechanic mate I found CBC Bearings where I could pick up 2 sets of rear bearings & new rear hubs for $560.
Now the only drama is fitting them. Any1 done this job b4? any pointers ?
Share this post
Link to post
take the hubs off and take them to a decent 4wd workshop and get them to press the bearings out.
you need a big mofo press
Share this post
Link to post
Is the hub/bearing setup like the fronts?
Share this post
Link to post
correction just got the bearings and hubs today $485 for both sides :spoton:
I am hoping its like the fronts where you can literally pull the old off and put a new on. But because its IRS rear I have a feeling its not going to be as simple.
a massive press? my old man's got a 10t press in the shed ... should be enough to press new bearings onto the new hubs ? apparently ford has a "specialty" tool to remove the old bearings from the hubs without damaging the backing plate ? (mechanic mate of mine's words) so I am hoping the bearing and hub isn't pressed onto the backing now :blink:
Share this post
Link to post
They are. 10tn should do it. I dont know what the "special" tool is but I wouldnt be suprised if its designed to support the upright while the hub and bearing is pressed out as its and odd shape and only cast so it could easily be bent if pressure is applied in the wrong spot.
Share this post
Link to post
Job Fail. :censored:
got everything taken off down to sliding the knuckle off the half shaft to no avail, seems to be rock solid onto the half shaft and I'm not about to pull the half shaft out of the diff to then press it away from the knuckle ...
so now I have put everything back on, gotten the camber and toe set as best I could (with eye) and am now bracing myself to max out the credit card and get ford to do it :bangcomputer:
Share this post
Link to post
Posted (edited)
Take it a Ford dealer and you'll pay sh*tloads.
Take it to a taxi workshop, they do this stuff all the time.
Your user info says that you're in Brisbane. Contact Jastel on www.fordforums.com.au (very knowledgeable taxi mechanic). I think he's on the Gold Coast - see if he can do it or if he can recommend a workshop in Brisbane.
Edited by PhilMeUp
Share this post
Link to post
The halfshaft usually needs a good spray in the splines with some crc and a good belt with a copper hammer.. Screw the nut on the shaft till its flush with the end and belt it. This way wont damage threads. The shafts are never easy to come out of the hub. Once youve done that,you still need to press the hub apart to replace bearing. If only they were as easy as the front lol.
Share this post
Link to post
Yeah used a good amount of CRC and tried hitting the hell outta it with a hammer, ended up grabbing a puller outta the old man shed, ended up bending 2 of the arms on it straight! there only rated to a ton....
Its at ford atm I got some holidays from work paid out so it should cover it. just annoying.
Share this post
Link to post
Problem Sorted! $1200 Lighter (with a wheel alignment on all 4 wheels) found out that whoever had done the bearings last time didn't line the splines up and absolutely destroyed the hubs. luckily the hubs are weaker than the half shafts
Share this post
Link to post
Followers 0
    No registered users viewing this page.
  • Donation Box
    Please donate to support the community.
    We appreciate all donations!
