micheal Member 69 Member For: 15y 7m 10d Posted 21/06/11 10:54 AM Share Posted 21/06/11 10:54 AM So short story I bent a rod in my ba xr6 turbo mk2. So my insurance is paying a bit towards it and ill be paying the rest.Any help/imput into what parts I should use/install tp make it reliable. So far I know I have to put stronger rods, pistons, change oil pump gears( do I need to change pump aswell) head studs bearings etc? Its already got valva springs Cheers guy any help greatly apreciated Link to comment Share on other sites More sharing options...
spoolxr6 Member 312 Member For: 13y 4m 13d Posted 21/06/11 11:21 AM Share Posted 21/06/11 11:21 AM You have most of the gear down. Just add a main girdle to support the main caps from twisting under load and a race balancer to protect the engine from nasty harmonics. Also have the ports on the crank shaft chamfered for better oil flow. Have the block sonically tested for wall thickness and find someone that uses a torque plate when they bore and hone the block to ensure a perfectly cylindrical bore. Then you need the engine blueprinted by someone that knows how to get the tolerances right. I used Atomic for all the machine work and then assembled it all myself. Brad is very helpful and will be able to help you out. With the right rods the engine will be good for over 600rkw. Good luck with your build. Link to comment Share on other sites More sharing options...
micheal Member 69 Member For: 15y 7m 10d Posted 21/06/11 11:30 AM Author Share Posted 21/06/11 11:30 AM Yeah hard part is that insurance have say as to where I got work done Link to comment Share on other sites More sharing options...
spoolxr6 Member 312 Member For: 13y 4m 13d Posted 21/06/11 11:34 AM Share Posted 21/06/11 11:34 AM See if you can negotiate with them. Find out how much the quote is from where they want the work done and then you pay the difference from where you want the work done. Otherwise you are just going to have to go with who they want which is going to be the cheapest probably. Link to comment Share on other sites More sharing options...
scottay Member 366 Member For: 13y 11m 4d Posted 21/06/11 12:02 PM Share Posted 21/06/11 12:02 PM how the fk did u get insurance to pay !! Link to comment Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 16y 1m 17d Gender: Male Location: Sydney Posted 21/06/11 12:05 PM Share Posted 21/06/11 12:05 PM how the fk did u get insurance to pay !!Prob took it for an accidental swim! Link to comment Share on other sites More sharing options...
micheal Member 69 Member For: 15y 7m 10d Posted 21/06/11 12:10 PM Author Share Posted 21/06/11 12:10 PM Yeah it sucked water into the engine causing it to bend a rod Link to comment Share on other sites More sharing options...
micheal Member 69 Member For: 15y 7m 10d Posted 23/06/11 06:52 AM Author Share Posted 23/06/11 06:52 AM So talked to the guy doing the rebuild and he want to use malhe pistons, scat rods, acl bearing kitSo parts I want to add are-Billet oil pump gears ( whats the standard pump good for)Arp head studs 12mm Race balencerAnd a girdle plate fitted to tie it all together.He also uses a torque plate when boring and honing.So I need to get it ballenced as its a inline6 and what sort of price should I pay to do it. Also anyone want to explain blueprint to me and rough price cheers micheal Link to comment Share on other sites More sharing options...
Nomis Member 231 Member For: 13y 11m 7d Gender: Male Posted 23/06/11 10:11 AM Share Posted 23/06/11 10:11 AM Aren't inline sixes self balanced? Link to comment Share on other sites More sharing options...
micheal Member 69 Member For: 15y 7m 10d Posted 23/06/11 10:38 AM Author Share Posted 23/06/11 10:38 AM that's what I thought Link to comment Share on other sites More sharing options...
