robbay91 Member 68 Member For: 11y 8m 9d Gender: Male Posted 21/01/14 10:44 AM Share Posted 21/01/14 10:44 AM Hey guys what offsets do u recommend for the flush look on 11 inch rims for an fg ute? Link to comment Share on other sites More sharing options...
Banto New Member 22 Member For: 8y 9m 14d Gender: Male Location: Tweed Heads Posted 26/11/16 02:27 AM Share Posted 26/11/16 02:27 AM Do bigger wheels impact on speedometer readings and does it affect cruise control or any other systems? I would investigte before spending the hard earned paticularly on FG MK2 XR6t Utes. They can be a tad sensitive in some areas. Just saying. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 4m 4d Gender: Male Location: Probably above atmospheric pressure Posted 26/11/16 07:40 AM Share Posted 26/11/16 07:40 AM Speedo readings come from the rotations of the wheel, so changing the overall diameter will indeed affect speedo. A new set of tyres compared to when they are bald will also affect accuracy. If you swap rim size but the tyre you put on is the same diameter as before, then there would be no change. It pays to check against GPS indicated speeds (plenty of smartphone apps) at 100km/h on nice flat highway to get a feel for it. You can also use online circumference calculators like www.willtheyfit.com Keep the front and rear circumference close to each other to avoid funny behaviour from driver aids! I forget the percentage though. Link to comment Share on other sites More sharing options...
