dan(nthqld) Member 47 Member For: 15y 2m 10d Gender: Male Location: Townsville Posted 05/03/10 08:15 AM Share Posted 05/03/10 08:15 AM (edited) I have a 2004 BA mk2 xr6t and today it started playing up.I have just been on a long trip from townsville to sydney and back (over a few days) and on the way back about 400km from home the car started feeling a bit sluggish. Whilst going to overtake a car I planted the right foot down, car started coming up to speed then all of a sudden the power just disappeared. it was like I was driving a n/a. Felt like no boost getting through at all. I could hear the turbo spooling just fine, just wasnt creating power.I slowed right down then speed up slowy keeping it under 3grand. Nothing happened all seemed fine. as soon as I started putting the foot right down to higher revs it did it again. I have put spitfire through it but it doesnt seem to be a fuel issue as there is no rough idle now rough acceleration when revs are down low.Im not sure here but could this be a problem with the waste gate actuator not functioning correctly?Car is completely stock and only had it serviced about 3000kms ago.If u need any more info let me knowThanksedit: also forgot to mention wen accelerating at the high revs I can hear like a fffffut ffffut sound from the exhaust Edited 05/03/10 08:20 AM by dan(nthqld) Link to comment Share on other sites More sharing options...
kirjo Member 113 Member For: 14y 10m 10d Gender: Male Location: Brisbane Posted 05/03/10 01:51 PM Share Posted 05/03/10 01:51 PM (edited) How old are your coil packs mate? Loss of power on boost usually means coil packs are screwed. You can pick up genuine sets on ebay for around $160.cheers, J Edited 05/03/10 01:55 PM by kirjo Link to comment Share on other sites More sharing options...
dan(nthqld) Member 47 Member For: 15y 2m 10d Gender: Male Location: Townsville Posted 05/03/10 11:59 PM Author Share Posted 05/03/10 11:59 PM Well since ive had the car, just over a year, I have never replaced them so I presume they have never been changed. im trying to put the car in this week to see if it can get fixed. Thanks Link to comment Share on other sites More sharing options...
xr6turbs boosting Donating Members 391 Member For: 17y 10m 4d Gender: Male Location: Glendene, Auckland NZ 0602 Posted 06/03/10 02:34 AM Share Posted 06/03/10 02:34 AM is it spluttering?if so could be the spark plugs Link to comment Share on other sites More sharing options...
dan(nthqld) Member 47 Member For: 15y 2m 10d Gender: Male Location: Townsville Posted 06/03/10 11:29 AM Author Share Posted 06/03/10 11:29 AM na its not spluttering, revving up its fine til about 3000rpm then the power disappears, then it will stay without power all the way to 6grand whilst making intermitent ffffut fffffut sounds out of the exhaust Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 14y 5m 30d Gender: Male Location: Far north queensland Posted 06/03/10 10:18 PM Share Posted 06/03/10 10:18 PM checked for boost leaks? Link to comment Share on other sites More sharing options...
BailZ Member 25 Member For: 17y 4m 13d Gender: Male Location: Brisbane, QLD Posted 08/03/10 12:27 AM Share Posted 08/03/10 12:27 AM Possibly overboost? Any recent mods? Link to comment Share on other sites More sharing options...
Turbo Train Member 17 Member For: 15y 2d Gender: Male Location: Adelaide Posted 08/03/10 02:15 AM Share Posted 08/03/10 02:15 AM I have a 03 XR6T, it ran fine under 3000rpm, but when it wanted to boost it would loose power and wouldn't gain revs easily and the same exhaust sound you described, just missing under boost, it was just a spark plug (could also be a coil as stated above), replaced them and the fun returned Link to comment Share on other sites More sharing options...
dan(nthqld) Member 47 Member For: 15y 2m 10d Gender: Male Location: Townsville Posted 08/03/10 09:29 AM Author Share Posted 08/03/10 09:29 AM had a look for boost leaks. there was a hose disconnected near the "blow off valve". I placed it back on and drove it. seemed fine. drove it the next day and problems again. dunno if I just got lucky or wat. seems to be no other boost leaks. there was a small bit of oil in the turbo. only a small amount and a little bit on the intake side. is this normal?thanks turbo I am trying to get the car in this week so they can have a look at the coil packs and plugs Link to comment Share on other sites More sharing options...
dan(nthqld) Member 47 Member For: 15y 2m 10d Gender: Male Location: Townsville Posted 15/03/10 10:39 AM Author Share Posted 15/03/10 10:39 AM (edited) Took car to mechanics today. They hooked it up to diagnostic tool, no fault codes. They took it for test drive and it wouldnt play up. I stopped in the afternoon and went for drive with them. Couldnt get it to do it - Whilst driving home I gave it a stab and there it was. It feels even worse now, losing a lot of power, and also you can hear the turbo spooling loud as, normally very quiet. Ive checked all intake pipes and vacumn hoses and everything I can think of for boost leaks and nothing. So now im stumped. Dunno wat to do. is there a way to test coil packs other then try them on a different car? Im thinking its either them or a spark plug, but apparently no miss was showing on the computer they connected :S Edited 15/03/10 10:40 AM by dan(nthqld) Link to comment Share on other sites More sharing options...
