tufgia Member 15 Member For: 14y 7m 27d Posted 25/02/10 02:37 AM Share Posted 25/02/10 02:37 AM Hey guys I am currently building an xf drift car that will be powered by a xr6 turbo engine, I'm currently trying to figure out what ecu to use, I can pick up a wolf 3d with hand controller for prettycheap, just wanted to know if any one was using one or if any one new of if it can run with this motor fine. Link to comment Share on other sites More sharing options...
BensXR6T Member 478 Member For: 15y 2m 22d Gender: Male Location: Burpengary QLD Posted 26/02/10 01:55 PM Share Posted 26/02/10 01:55 PM (edited) Probably be easier to stick with the standard ECU rather then going down the aftermarket line. A flash tuner has been tried and tested in many cars and really doesn't need to be replaced.Keep us updated on the build Edited 26/02/10 01:58 PM by BensXR6T Link to comment Share on other sites More sharing options...
philbaxr6t Member 102 Member For: 15y 6m 21d Gender: Male Location: nor perth Posted 26/02/10 02:31 PM Share Posted 26/02/10 02:31 PM hey I got bf xr6t ecu u can own it for 350... cheeper option than buying new Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 18y 6m 5d Gender: Male Location: Perth Posted 26/02/10 03:32 PM Share Posted 26/02/10 03:32 PM it would be a mammoth task to install ALL the required electronics to run a factory ecu. You would basically need a whole car to transplant it fromIm a big fan on the wolf ecu's, have been playing with them for yearsEF Falcon with a wolf ecu:WOLF3D Version 4 Dealer Tech 9.pdf Link to comment Share on other sites More sharing options...
Dale@CHE Member 52 Member For: 15y 4m 23d Posted 15/03/10 03:21 AM Share Posted 15/03/10 03:21 AM ive tune a EB with a BA XR6T motor and factory ecu setup in it, the wiring was done by Sideshows Performance wiring and everything worked perfectly, even the factory boost control.Dale Link to comment Share on other sites More sharing options...
383ongiggle Donating Members 53 Member For: 14y 5m 7d Gender: Male Location: Newman, WA Posted 16/03/10 10:31 AM Share Posted 16/03/10 10:31 AM (edited) hey I got bf xr6t ecu u can own it for 350... cheeper option than buying new Will a BF xr6t ecu plug into a BA mark 2 xr6 without any issues? Do I even need a t ecu if im doing a conversion to my xr6 or can I just utilize the stock xr ecu? If not I might grab that ecu off you bud.Stu Edited 16/03/10 10:36 AM by 383ongiggle Link to comment Share on other sites More sharing options...
BensXR6T Member 478 Member For: 15y 2m 22d Gender: Male Location: Burpengary QLD Posted 16/03/10 01:33 PM Share Posted 16/03/10 01:33 PM You can use the stock ecu, but will have to get the car towed to ford or a tuner for the correct tune to be uploaded. BF ECU will not work with a BA, won't talk to the BEM. Link to comment Share on other sites More sharing options...
383ongiggle Donating Members 53 Member For: 14y 5m 7d Gender: Male Location: Newman, WA Posted 16/03/10 09:28 PM Share Posted 16/03/10 09:28 PM (edited) Thanks for the heads up mate.Stu Edited 16/03/10 09:28 PM by 383ongiggle Link to comment Share on other sites More sharing options...
rob82 Member 65 Member For: 18y 4m 9d Posted 17/03/10 11:39 AM Share Posted 17/03/10 11:39 AM So much missinformation here. If you go to the right tuner all you need to do is turn of the PATS(Passive anti theft system) in the ECU and it will no longer look for the body control to make sure it has a valid key.All you need is a standard BF ECU and harness and talk to Chiptorque as they have done this conversion before. A much better option than wolf and much cheaper. PM me if you need help - I know what wiring changes need to be done. Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 17y 10m 9d Gender: Male Location: Sydney NSW Posted 17/03/10 01:03 PM Share Posted 17/03/10 01:03 PM Yeah, dollar for dollar it would work out cheapest for the DIYer to use the stock ford pcm & wiring... its not too hard to follow a loom and figure out which wires and sensors go where. Then once your done, use the stock tune to get it up and running... then do the finaly edit tuning when its all sorted. Link to comment Share on other sites More sharing options...
