BLN68U Member 43 Member For: 18y 8m 6d Posted 20/01/06 08:08 AM Share Posted 20/01/06 08:08 AM What gap size do the plugs have to be reset to and is it neccesarily to use a "colder range plug"! THANKS Link to comment Share on other sites More sharing options...
Street Tuner Member 727 Member For: 21y 4m 1d Posted 20/01/06 11:18 AM Share Posted 20/01/06 11:18 AM Set the stock plugs to 0.8mm and no more problems. Its a common task with the 'T' Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 1m 8d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 20/01/06 11:29 AM Share Posted 20/01/06 11:29 AM Many use .9mm, usually a tuner will tell you ifn they are too fat once you defer from the generic tune Link to comment Share on other sites More sharing options...
thebrunks Member 665 Member For: 19y 9m 15d Location: Gold Coast Posted 20/01/06 12:16 PM Share Posted 20/01/06 12:16 PM (edited) I've set mine to .89mm & they're still blowing out!!!Next step .7-.8mm!Russ Edited 20/01/06 12:17 PM by thebrunks Link to comment Share on other sites More sharing options...
maca's rapid t Member 2 Member For: 18y 1m 3d Posted 31/03/06 10:57 PM Share Posted 31/03/06 10:57 PM recently got flash tune, can I run .89 plug gap for 8psi program as you do with program 3 (10psi) ? is there a real gain in taking the middle mufler out for either program 2 or 3? Link to comment Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 18y 10m 5d Location: Canberra Posted 01/04/06 12:24 AM Share Posted 01/04/06 12:24 AM mate, from other peoples experience, not much gain in the muffler job unless you just want a bit more growl. Spark plugs should be fine at .89... however, I had mine gapped to this, and then when I had it back on the dyno with another tune and all my go fast bits on, they were breaking down at around 3800rpm... so I have re-gapped them further to .75.. Link to comment Share on other sites More sharing options...
kawerx TerriGhia Donating Members 206 Member For: 18y 3m 3d Posted 01/04/06 05:12 AM Share Posted 01/04/06 05:12 AM I gapped mine to 0.8.no problems after that.it may depend on your mods,do you have any?just edited? Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 19y 4m 22d Gender: Male Location: SoR, WA Posted 19/05/06 08:05 AM Share Posted 19/05/06 08:05 AM GuysIve had a custom tune now for a while and I dont think I have had any issues with my spark plugs but was told to get some new ones because once you up your boost the plugs dont have there great life span any more.What size gap should I have? I am running 10psi.CheersAdrian Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 4m 2d Gender: Male Location: Perth, WA Posted 19/05/06 08:15 AM Share Posted 19/05/06 08:15 AM Adrian,I would run 0.9 - 0.8 mm.If this cause any problems with smoothness of the engine under load, then replace the plugs. Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 19y 4m 22d Gender: Male Location: SoR, WA Posted 19/05/06 08:32 AM Share Posted 19/05/06 08:32 AM CheersSo somewhere between there. Link to comment Share on other sites More sharing options...
