quick xr6 Suspended 229 Member For: 16y 1m 12d Gender: Male Location: sydney Posted 29/05/09 01:07 PM Share Posted 29/05/09 01:07 PM Hi I have bf xr6 turbo and fitted a catch can on it I ran a hose from the rocker cover the catch can and from the can to the inlet port on the crossover some told me it is wrong it should ran from the pcv valve to the can and from the can to rocker cover can some one tell me witch way please. Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 15y 9m 9d Gender: Male Location: Earth Posted 29/05/09 02:35 PM Share Posted 29/05/09 02:35 PM Nearly right. Try running it from the breather to the catch can. Not the PCV valve. Then to the crossover. Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 18y 8m 21d Gender: Male Location: The 8th Dimension Posted 29/05/09 03:10 PM Share Posted 29/05/09 03:10 PM The search function is your friend Rapids canhttp://www.fordxr6turbo.com/forum/index.ph...mp;hl=catch+canand my Installhttp://www.fordxr6turbo.com/forum/index.ph...c=49463&hl= Link to comment Share on other sites More sharing options...
quick xr6 Suspended 229 Member For: 16y 1m 12d Gender: Male Location: sydney Posted 30/05/09 10:01 AM Author Share Posted 30/05/09 10:01 AM Nearly right. Try running it from the breather to the catch can. Not the PCV valve. Then to the crossover. sorry a bit lost. Trying to stop the map sencor getting oily then the car rans like sh*t.Breather to catch can do you mean from the rocker cover to the can and then were? sorry about spelling mistakes stressed pic would be go because I want to do it tomorow thanks Link to comment Share on other sites More sharing options...
ETM Member 1,194 Member For: 17y 15d Gender: Male Location: syd south Posted 30/05/09 10:10 AM Share Posted 30/05/09 10:10 AM Does the catch can have an air filter on it? Also how many fittings does it have on it Link to comment Share on other sites More sharing options...
quick xr6 Suspended 229 Member For: 16y 1m 12d Gender: Male Location: sydney Posted 30/05/09 10:15 AM Author Share Posted 30/05/09 10:15 AM Does the catch can have an air filter on it? Also how many fittings does it have on it2 fittings and air filter Link to comment Share on other sites More sharing options...
ETM Member 1,194 Member For: 17y 15d Gender: Male Location: syd south Posted 30/05/09 11:11 AM Share Posted 30/05/09 11:11 AM Well that type of can is designed to completely replace the pcv system which can lead to higher crankcase pressures. To fit it the way that can is designed run both rocker cover fittings to the catch can and block off the fitting at the inlet manifold and also the one at the turbo inlet pipe.IMO it is not an ideal system but you dont really have a choice when using that can. Link to comment Share on other sites More sharing options...
quick xr6 Suspended 229 Member For: 16y 1m 12d Gender: Male Location: sydney Posted 30/05/09 11:33 AM Author Share Posted 30/05/09 11:33 AM Well that type of can is designed to completely replace the pcv system which can lead to higher crankcase pressures. To fit it the way that can is designed run both rocker cover fittings to the catch can and block off the fitting at the inlet manifold and also the one at the turbo inlet pipe.IMO it is not an ideal system but you dont really have a choice when using that can.thanks alot but will it kill the engine at all SORRY to a pest Link to comment Share on other sites More sharing options...
ETM Member 1,194 Member For: 17y 15d Gender: Male Location: syd south Posted 30/05/09 11:45 AM Share Posted 30/05/09 11:45 AM nah wont kill it lol, you may just get some extra crankcase pressure, keep an eye on your dipstick and check the level of the oil in the can Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 17y 2m 14d Gender: Male Location: QLD Posted 30/05/09 11:59 AM Share Posted 30/05/09 11:59 AM Just remove the filter & Block it where it came off with a cap.Run the hose from the PCV valve to the can, then from the can to just before theturbo intake. the factory setup draws in oil fume anyway so its not going to be any different.You can make it better by if possible run a foam filter inside the can so it trapsas much oil as possible from returning to the intake.the tyre of catch can I have has a removeable top so I can do this.It would be a better option to purchase a non atmo type can.the whole idea is to remove crankcase pressure with less oil contamination as possiblewhile keeping it legal. Link to comment Share on other sites More sharing options...
