bda12pleaseu Member 94 Member For: 16y 3m 9d Gender: Male Location: newcastle Posted 31/01/09 08:55 AM Share Posted 31/01/09 08:55 AM (edited) please do not reply yetafter looking through the forum I found a heap of topics but not much info on doing the task so I thought id do it myself.this took approx 6 hrs with me and a mate we are fairly mechanically minded however are not mechanics I would suggest you know how to swing a spanner and know how to use a drill if u dont this aint for u...replaced my diff bush in the driveway and found wasn't as bad as we thought it would be, more time consuming than anything else.This is merely a guide which u use at your own risk in know way will I be held responsible for damage or injuryyou will need...Nolathane bush kitmedium strength thread locker18mm spanners15mm spannerssocket setshifterdrill8mm drill bit or close to itdie grinder70mm hole saw (pilot drill removed)see figure 10barrel sander see figure 111.back car on ramps2.chock front wheels3.spray paint or texta on witness marks so the IRS assembly is reinstalled it same place (see figure 1)4.locate and disconnect exhaust mount (see fig2)5.locate and remove 2 bolts(1 either side) in lower portion of shock absorber (see fig 3)6.locate and remove 1 bolt towards rear of diff housing just above the bush in question (see fig 4)7.locate and remove 8 bolts (4per side) (see fig's 1,5,6)8.firstly remove the brake lines out of there bracket on the hub assembly then care fully jack body up off IRS assy, take this section slowly as u dont want to bend studs or strip there threads, you can use 2 socket extension bars or suitable pry bars to pry away IRS assy from studs a bit. we made a timber stack and jacked of the tow bar (see fig A). if u dont have a tow bar you need something in the centre of the car or evenly jack at sides with 2 jacks remembering to use car stands before getting underneath car. make note that the breather hose will come off the diff housing and to reconnect on installation (see fig 7).we jacked car until studs were about 20mm clear of the holes this was enough to allow us to continue. (see fig 1 for holes to pry from)9.remove bolt from bush10.drill hole approx 8mm in the aluminium part of bush about 25mm in (see fig 11.using existing hole in bush and newly drilled hole insert 2 suitably sized bolts and turn both at same time with a shifter(see fig 9 and 9.1) 2 full rotations this will break centre out of bush and then can be pulled from bush with vice grips or multi grips.12.using flat blade screwdriver and hammer break out most of the big bits of rubber.13.using a 70mm hole saw with pilot drill removed similar to the one in (figure 10) cut throught old bush carefully not to cut into diff housing.14.using barrel sander (figure10) and drill or die grinder sand the rest of the bush out.15.once inside bush housing is back to metal u can aply a quick coat of paint for rust protection and install bush using bolt supplied with kit and pack with old centre to make up the thread, thread into diff housing. you may need to put a piece of wood between diff and bush housing to stop diff from moving while tightening bolt.16.once bush is all the way home cut bolt to length and install bolt with washers supplied and medium strength thread locker.17.reinstall IRS assy reverse steps 4 through 8 inclusive lining up witness marks and applying medium thread locker to all threads. Edited 31/01/09 09:04 AM by bda12pleaseu Link to comment Share on other sites More sharing options...
bda12pleaseu Member 94 Member For: 16y 3m 9d Gender: Male Location: newcastle Posted 31/01/09 09:23 AM Author Share Posted 31/01/09 09:23 AM (edited) post away ppl let me know what u think 1st set of pics are wrong order... Edited 31/01/09 09:26 AM by bda12pleaseu 1 Link to comment Share on other sites More sharing options...
Guest Spinifex Guests Posted 31/01/09 10:26 AM Share Posted 31/01/09 10:26 AM Sweet! Hows it feel now? Link to comment Share on other sites More sharing options...
bda12pleaseu Member 94 Member For: 16y 3m 9d Gender: Male Location: newcastle Posted 31/01/09 10:29 AM Author Share Posted 31/01/09 10:29 AM much better. the original 1 was shagged Link to comment Share on other sites More sharing options...
howitzer85 Member 241 Member For: 17y 1m 8d Gender: Male Location: The marsh... Posted 31/01/09 11:16 AM Share Posted 31/01/09 11:16 AM excellent write up!coulda used this a few months ago, I payed a fortune to get mine replaced... Link to comment Share on other sites More sharing options...
EXR6T Member 224 Member For: 16y 6m 11d Gender: Male Location: Melbourne Posted 01/02/09 01:07 AM Share Posted 01/02/09 01:07 AM I'm gonna put the car on ramps and have a look around to see if I feel confident enough to do this myself. if yes then you coulda just saved me a bit of money!!!!thanks for the great write up... 1 Link to comment Share on other sites More sharing options...
bda12pleaseu Member 94 Member For: 16y 3m 9d Gender: Male Location: newcastle Posted 01/02/09 07:46 AM Author Share Posted 01/02/09 07:46 AM (edited) glad to help,really guys if u know your way around a car a bit and have tools and know how to use them + a mate to help really is 2 person job it aint that bad.. Edited 01/02/09 07:48 AM by bda12pleaseu Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 18y 8m 20d Gender: Male Location: OZ Posted 05/02/09 08:00 AM Share Posted 05/02/09 08:00 AM I'm giving this a crack this weekend, if you want any specific photos let me know and I'll take some happy snaps. Link to comment Share on other sites More sharing options...
bda12pleaseu Member 94 Member For: 16y 3m 9d Gender: Male Location: newcastle Posted 08/02/09 10:54 AM Author Share Posted 08/02/09 10:54 AM so mate howd u go? 1 Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 18y 8m 20d Gender: Male Location: OZ Posted 09/02/09 03:22 AM Share Posted 09/02/09 03:22 AM so mate howd u go?Have not got around to doing it yet! I need to get some ramps, a spare pair of hands and a 70mm hole saw....only have a 65mm or 80mm at home, will either of those suffice as I haven't measured myself? Drilling a 100mm in the boot well seems very tempting also!! Link to comment Share on other sites More sharing options...
