HI PSI Member 1,567 Member For: 17y 10m 25d Gender: Male Location: Central Queensland Posted 17/11/08 10:59 AM Share Posted 17/11/08 10:59 AM Hi guys and gals. I have just purchased a spare secondhand housing. I will be building a new bottom end and I have a few questions about external wastegates before I proceed any further. I openly admit that this is an area that I have little/No knowledge. So please be gentle... I have done a few searches and have not been able to find any information on this forum. Any help greatly appreciated.1) Which is better (Value for money) ?2) Is an external gate only necessary for extremely high powered engines?3) Is there any power gains/losses from using either?4) If I get an external wastegate mod. How will this affect different boost levels with my different tunes?Does the boost level get adjusted by the PCM or does it have to adjusted manually by changing springs in the blow off valve? 5) I already have a new 12 pound actuator sitting here . Will a modded internal gate be sufficient?6) Can anyone advise me as to the cost of both methods? Thank you for you time and advice Cheers Brad Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 2m 11d Gender: Male Location: SW Sydney Posted 17/11/08 11:08 AM Share Posted 17/11/08 11:08 AM Hi guys and gals. I have just purchased a spare secondhand housing. I will be building a new bottom end and I have a few questions about external wastegates before I proceed any further. I openly admit that this is an area that I have little/No knowledge. So please be gentle... I have done a few searches and have not been able to find any information on this forum. Any help greatly appreciated.1) Which is better (Value for money) ? Internal is generally cheaper2) Is an external gate only necessary for extremely high powered engines? No, it is better for boost control on high or mid power levels3) Is there any power gains/losses from using either? I can't see any losses, but both give you greater potential for making power4) If I get an external wastegate mod. How will this affect different boost levels with my different tunes?Does the boost level get adjusted by the PCM or does it have to adjusted manually by changing springs in the blow off valve? The external gate has a base spring pressure like the internal, so whatever spring is in the gate will be your lowest boost. The boost solenoid will still control the boost level.5) I already have a new 12 pound actuator sitting here . Will a modded internal gate be sufficient? These are good for well into the 300's, but external may be more precise6) Can anyone advise me as to the cost of both methods? Check out ETMs external gate mod for pricing. The internal porting should only cost a couple of hundred Thank you for you time and advice Cheers Brad Link to comment Share on other sites More sharing options...
spine Donating Members 642 Member For: 18y Gender: Male Location: Footscrayastan Posted 17/11/08 06:32 PM Share Posted 17/11/08 06:32 PM I would go the external gate, you will have alot better control. Something also to consider will be if you do go external, you will have to modify your dump pipe to plumb back the gate, or vent to atmosphere and piss your neighbours off!!! Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 17y 10m 30d Gender: Male Location: Sydney NSW Posted 17/11/08 09:55 PM Share Posted 17/11/08 09:55 PM Yeah externals are much better, cost is higher, but not by a huge amount.There's a few different mounting options, such as off the exhaust housing offered by ETM, or off the centre section of the manifold if you don't want to cut into the turbo. Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 15y 8m 27d Gender: Male Location: Victoria Posted 17/11/08 11:09 PM Share Posted 17/11/08 11:09 PM (Senna)Well answered! Link to comment Share on other sites More sharing options...
Guest Guests Posted 17/11/08 11:40 PM Share Posted 17/11/08 11:40 PM If funds allow, go external mate Vent to atmosphere as well so you can sound like a muzzed VL! Lol Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 15y 8m 27d Gender: Male Location: Victoria Posted 17/11/08 11:47 PM Share Posted 17/11/08 11:47 PM Wont an external make it illegal??? LOL Link to comment Share on other sites More sharing options...
Guest Guests Posted 17/11/08 11:50 PM Share Posted 17/11/08 11:50 PM Vented to atmo it will for sure! Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 19y 6m 26d Gender: Male Posted 18/11/08 12:19 AM Share Posted 18/11/08 12:19 AM (edited) What power level are you aiming for?Which turbo will you be using.An external gate is not always needed.More info please.Thanks Edited 18/11/08 12:20 AM by Typhoon Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 16y 3m Gender: Male Posted 18/11/08 04:07 AM Share Posted 18/11/08 04:07 AM with an external gate u can really push the stock turb. I would definately be using an external gate with a built motor. Link to comment Share on other sites More sharing options...
