nelsonian101 Donating Members 961 Member For: 15y 9m 29d Gender: Male Location: Sydney Posted 21/06/17 09:54 AM Share Posted 21/06/17 09:54 AM I'm running a couple of seconds under the v8 Brute Ute lap records in my over developed pig, so I'd be looking for a 1min05 on the long track hopefully. 58? Dreamin...... Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 21/06/17 10:41 AM Share Posted 21/06/17 10:41 AM I reckon you could go 1.05. Iam at a low 1.08 in my F6, but had crap tyres. BUT I have done 1000s of laps at that track. 1 Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 15y 4m 29d Gender: Male Location: Perth Posted 22/06/17 08:17 AM Share Posted 22/06/17 08:17 AM yep. Experience at track > type of car**usually Link to comment Share on other sites More sharing options...
furiousgibbon Member 86 Member For: 16y 8m 4d Posted 25/06/17 12:52 PM Share Posted 25/06/17 12:52 PM I took the F6 back out to Barbagallo yesterday for the Infinite Time Attack event. Pretty good event, mostly jap cars but some of them were bloody rapid. F6 was faster than most though! Lots of traffic so it was difficult to get clean hotlaps. This was my first time on track since getting some work done to the car (2 tunes, venom cat, 1000cc injectors, jonny tig IC, oil pump gears, IMS diff hat). I was running the track tune which is a smooth 335kw at the hubs at 6krpm. It felt bloody good, great power, not wild out of corners and it felt like it would rev way past 6k, but unfortunately I was feeling pretty unwell, and with well worn NT01s and brake fluid that hasn't been changed in 2.5 years I wasn't pushing it hard. Still managed a 1.08.7 long track and 58.7 short track, which was good enough for 10th and 8th outright in each layout. Big problem was the bloody thing overheated in less than 3 laps and ambient temp was only 19! I've had the car overheat before on track but that was on a 42C day, so understandable. This was really disappointing. The undertray has been removed, I think because the radiator needs to be moved back to fit this IC, so that's gonna be part of the problem as I'm thinking that would create positive air pressure behind the radiator. But that can't be the only thing. I think I've screwed my chances for a larger radiator with this IC... gonna have to figure something out as track days temperatures don't get much milder than this... video of my best lap on each layout. I thought the short track was awesome fun, got to use 2nd gear and skip the frustrating basin. 5 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 25/06/17 03:30 PM Share Posted 25/06/17 03:30 PM (edited) You need a large radiator and a large engine oil cooler. Your braking way to early down the hill. Edited 25/06/17 03:32 PM by arronm Link to comment Share on other sites More sharing options...
furiousgibbon Member 86 Member For: 16y 8m 4d Posted 26/06/17 04:29 AM Share Posted 26/06/17 04:29 AM Yeah, lots of time lost all round, combination of being unwell and not having any confidence left in these tyres, they've been through a lot of events in the last 3 years, way overdue for replacement. I was half a second off the time I set with stock power. I'll look into oil coolers, I noticed oil temp was getting up there too but gauges based on derived values always read wild on track. I should get a proper sensor put in. I've looked into pwr radiators before but read comments about them corroding from coming in contact with the car. I'd probably give it a crack now but I think I'll have to change IC to be able to fit one in... Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 26/06/17 09:36 AM Share Posted 26/06/17 09:36 AM I can help with set up. Pm me if you like. Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 15y 9m 29d Gender: Male Location: Sydney Posted 27/06/17 10:26 AM Share Posted 27/06/17 10:26 AM Re: Overheating. lol Tell me about it.:) Even in 19 ambient. Boost is your enemy. Tried the coolant additives like Water wetter/purple ice but did stuff all. Tried waterless coolant. Same result. You Need to shroud the radiator with foam, remove air con condenser, allow hot air to get out by raising rear of bonnet (I have a custom made spacer (not washers) or bonnet vents via lazer pyrometer hot spotting. Don't disregard oil temps and assume decent oil cooler is fitted with cool air access and thermos fan. Thermo fan override switch was recently fitted and very effective allowing manual override. High volume radiator for coolant with cooler thermostat helps too. Water spraying and fans in pits help as well. Onto my 2nd PWR 55mm one. 2nd one fitted more carefully to prevent contact/stray current corrosion. Have also tried fenix and chinese ebay radiators. 2 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 27d Gender: Male Location: Perth Posted 28/06/17 06:17 AM Share Posted 28/06/17 06:17 AM (edited) Yeh but me and furious don't have slush boxes heating it up. Ditch the auto. My fenix 50mm is 4 years old no issues. Stray currents kills cooling system components just ask me Wiggum e85 is your friend for keeping temps down. Edited 28/06/17 06:20 AM by arronm Link to comment Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 15y 9m 29d Gender: Male Location: Sydney Posted 28/06/17 06:41 AM Share Posted 28/06/17 06:41 AM I agree and use E85 at the circuit. I had a Fenix for a while but it died in a crash and they no longer make them for FG (BF ok with different mounts) ZF stays cool now with high volume, lower finned sump and does not affect engine temps. Post above referred to engine coolant and engine oil temps. The manual thermo fan over ride switch was for the radiator/engine coolant and works really well staging in dummy grid and cool down laps. Has solved many problems for me as long as the hot air has an escape point via vents. Link to comment Share on other sites More sharing options...
