Mike85 Member 13 Member For: 16y 7m 25d Gender: Male Location: Melbourne Posted 28/10/07 08:14 AM Share Posted 28/10/07 08:14 AM hey all,just wondering if anyone knows what this problem could be, yesterday was pretty hot so I had my AC going. Then I noticed water dropping down from the glovebox area onto the floor mat on the passenger side of the vehicle. (LHF) I turned the AC off and after a little bit the water stopped dropping. I also washed the car a little earlier that day as well. Any info would be much appreciated. Link to comment Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 18y 4m 17d Gender: Male Location: Adelaide Posted 28/10/07 08:27 AM Share Posted 28/10/07 08:27 AM very common problem mate,the drain tube from your aircon is blocked easy fix Link to comment Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 18y 2m 16d Gender: Male Location: The Shire Sydney AUS Posted 28/10/07 12:00 PM Share Posted 28/10/07 12:00 PM Or it could be leaking heater core.... Link to comment Share on other sites More sharing options...
Mike85 Member 13 Member For: 16y 7m 25d Gender: Male Location: Melbourne Posted 29/10/07 12:07 AM Author Share Posted 29/10/07 12:07 AM so how would I unblock the drain tube for the AC?Where abouts is it? Link to comment Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 18y 2m 16d Gender: Male Location: The Shire Sydney AUS Posted 29/10/07 12:47 AM Share Posted 29/10/07 12:47 AM The drain hose sits directly above the gearbox to the left of it actually, it protrudes thru the tunnel a couple inches back from your firewall, use some coat hanger wire to unblock it. good luck with it Pete.. Link to comment Share on other sites More sharing options...
Mike85 Member 13 Member For: 16y 7m 25d Gender: Male Location: Melbourne Posted 29/10/07 05:13 AM Author Share Posted 29/10/07 05:13 AM cool, ill try that. thanks alot for the help Link to comment Share on other sites More sharing options...
Mike85 Member 13 Member For: 16y 7m 25d Gender: Male Location: Melbourne Posted 07/11/07 08:45 AM Author Share Posted 07/11/07 08:45 AM yeah, you guys were right. stuck the coat hanger in the draintube and the water pissed out. thanks again guys. Link to comment Share on other sites More sharing options...
Boony_1981 Member 32 Member For: 17y 2m Location: Townsville Posted 08/11/07 01:28 AM Share Posted 08/11/07 01:28 AM How about water coming out from the centre console and dripping down to the drivers feet?I went for a 2 hour drive and had the air-con on the whole way. About an hour into the drive I took a hard left hand corner and a river of water came from the centre console and dripped out onto my feet for about 15 seconds and then stopped. I got out and checked that the air-con drain was not blocked because it was dripping out a steady rate onto the road. Same thing happened on the 2 hour drive back home too.Any suggestions?....Other than not taking hard left hand corners anymore and not using the air-con anymore! Link to comment Share on other sites More sharing options...
ENVI.BA Member 146 Member For: 15y 4m 12d Gender: Male Location: 2155 Posted 07/03/10 05:32 AM Share Posted 07/03/10 05:32 AM ive got the same problem at the moment Link to comment Share on other sites More sharing options...
