Falchoon I see red Member 5,758 Member For: 21y 4m 2d Location: nowhere in particular Posted 25/05/07 08:27 AM Share Posted 25/05/07 08:27 AM I want to flush the cooling system of my auto BA XR6T, how much coolant will I need? Link to comment Share on other sites More sharing options...
Meggs_83 Member 114 Member For: 17y 18d Gender: Male Location: Esperance Posted 25/05/07 11:14 AM Share Posted 25/05/07 11:14 AM have a gander at thiscoolant.doc Link to comment Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 21y 4m 2d Location: nowhere in particular Posted 26/05/07 01:45 AM Author Share Posted 26/05/07 01:45 AM have a gander at thisMmmmmm...thanks - different answer to what I was given by local Ford dealer, if experience is anything to go by your answer is more accurate Meggs_83. Ford guy told me 5lt, your doc says 12.5lt, wonder if that is just coolant or total combined cooling system liquid ie water and coolant.Might have to get a 3rd opinion. Link to comment Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 17y 2m 4d Gender: Male Location: SYDNEY Posted 08/06/07 10:15 AM Share Posted 08/06/07 10:15 AM (edited) Mmmmmm...thanks - different answer to what I was given by local Ford dealer, if experience is anything to go by your answer is more accurate Meggs_83. Ford guy told me 5lt, your doc says 12.5lt, wonder if that is just coolant or total combined cooling system liquid ie water and coolant.Might have to get a 3rd opinion. Hi Falchoon5 lts will be only the coolant concentrate additive plus water.best thing to do is check you owners manual dude Pete Edited 08/06/07 10:16 AM by LUMO Link to comment Share on other sites More sharing options...
WPN XR6T Member 12 Member For: 17y 14d Gender: Male Posted 08/06/07 12:12 PM Share Posted 08/06/07 12:12 PM 33% Glycol 8.9L. Link to comment Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 17y 5m 10d Gender: Male Location: Perth, NOR Posted 08/06/07 05:15 PM Share Posted 08/06/07 05:15 PM Hey mate. I recently flushed my coolant and used the recommended R1-33 coolant. Bought it in a 5 litre concentrate bottle from Coventrys (around $50 from memory).On the back it says you can add 33% or 50% depending on what properties you want it to have (different boiling points....etc), so I listened to a mates advice and basically used close to 50% ratio of coolant to distilled water.It took about 4 litres of coolant to roughly the same amount of distilled water for me to get a 50/50 mix and get it up to the MAX mark on the overflow bottle. A bit more water was required once it opened up the thermostat and the water started flowing (make sure you crank the heater on too so it flows through there too)I hope that helps you. Link to comment Share on other sites More sharing options...
F6BF Member 438 Member For: 18y 4m 6d Location: Sydney Posted 09/06/07 03:18 AM Share Posted 09/06/07 03:18 AM I want to flush the cooling system of my auto BA XR6T, how much coolant will I need?It all depends on the glycol concentrate of the coolant33% is the standard mix ratio and 50% for extreme conditionsHTH Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 16y 11m 24d Gender: Male Location: ACT Posted 09/06/07 05:54 AM Share Posted 09/06/07 05:54 AM I want to flush the cooling system of my auto BA XR6T, how much coolant will I need?Changed my Coolant 2 weeks ago. Drained the system / radiator in to a container and got 7.4 litres out of it. The rest will not drain out. Got NULON LONG LIVE Concentrate and put 3 & 3/4 Litres in . The rest was Distilled Water from Woolworth or Coles.I now got a 50/50 mix. Link to comment Share on other sites More sharing options...
