XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 6m 26d Gender: Male Location: Perth, WA Posted 23/06/10 06:15 AM Share Posted 23/06/10 06:15 AM I just ordered a new OEM filter and some cooper washers. When I replace the filter is it worth pulling the feed line off and flushing it? Link to comment Share on other sites More sharing options...
kevo Member 286 Member For: 16y 4m Gender: Male Location: Wanneroo, Perth WA Posted 24/06/10 12:08 AM Share Posted 24/06/10 12:08 AM No, not worth it dude, don't bother replacing the filter unless its a ETM/ earls remote style filter Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 6m 26d Gender: Male Location: Perth, WA Posted 24/06/10 12:27 AM Share Posted 24/06/10 12:27 AM kevo, I am replacing the entire fitting that screws into the block. Turbo is not making any noises on mine with 100000kms so I'll just replace the filter and fitting.When I spoke to spare parts they told me that the oil feed filter/fitting was revised and not runs a bigger filter element inside the fitting. I am sure the ETM style setup is better in the long run but I can not justify the cost vs replacing the OEM filter.Cheers Link to comment Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 17y 5m 9d Gender: Male Location: Perth, NOR Posted 24/06/10 12:49 AM Share Posted 24/06/10 12:49 AM That is correct Goran. The new one I installed into the car had openings around double the size of my old filter. I had photos of the two side by side but its on my computer that died :/ Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 6m 26d Gender: Male Location: Perth, WA Posted 24/06/10 01:22 AM Share Posted 24/06/10 01:22 AM Thanks Mike. So they must have revised them quiet late as yours is a BF.I'll take some pictures when I do mine this weekend and post them up. Link to comment Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 17y 5m 9d Gender: Male Location: Perth, NOR Posted 24/06/10 01:26 AM Share Posted 24/06/10 01:26 AM Yeah it was either a BF MKII thing or introduced with the FG's. Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 6m 26d Gender: Male Location: Perth, WA Posted 24/06/10 01:54 AM Share Posted 24/06/10 01:54 AM Mike, your inbox if full. Link to comment Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 17y 5m 9d Gender: Male Location: Perth, NOR Posted 24/06/10 02:31 AM Share Posted 24/06/10 02:31 AM Inbox cleaned up Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 6m 26d Gender: Male Location: Perth, WA Posted 27/06/10 12:48 PM Share Posted 27/06/10 12:48 PM Finally got around to the turbo oil feed line while I am doing a number of other things. Glad to stay that after pulling the filter and feed line off, neither were blocked and the turbo was getting heaps of oil. This is on a 100000km engine that has been serviced as per Ford service schedule.Was not as easy to remove as I thought due to the location and lack of access. Would be much easier to do this while the oil filter if off. Also I found using deep sockets works best, I used a 22mm and 24mm deep socket with a short arm shifter that I could get in to hold one nut at a time as I undid them in order.Here are some pictures of the OEM filter next to the current (revised) OEM filter. Notice the new filter is much larger inside the fitting as well as the feed holes:I also pulled off the oil feed line to clean it out. The line was not blocked but I blew the oil out and then filled it with carby cleaner and let it sit for 5 min then blew it our with compressed air. Also hit it with some wet/dry and metal polish.Before:After: Link to comment Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 17y 5m 9d Gender: Male Location: Perth, NOR Posted 27/06/10 02:16 PM Share Posted 27/06/10 02:16 PM Nice work Goran Exactly what I did the first time I did mine. Link to comment Share on other sites More sharing options...
