ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 18y 9m 27d Gender: Male Location: Melbourne Posted 28/10/06 12:11 AM Share Posted 28/10/06 12:11 AM Ok here is the guide to upgrade your non illuminated switches to illuminated.Whats needed.Soldering Iron.Solder.Size #3 Solder-WickPLCC-2 or SMD 1206 LED's(14 for sedan or 6 for Ute/2 Window)SMD 1206 Resistors(10 for Sedan or 4 For Ute/2 Window)Screwdriver.Lift the switches out of the door by simply lift from the bottom of the switch using a small flat blade screwdriver refer to switch_lift.JPG.Once the switches are out, use a small flat bladed screwdriver to open the switch refer to switch_open.JPG. Once the switch comes apart , the actual switch mechanisms will fall out. Don't worry , just dont lose any.For a 4 window switch refer to Multi_Sedan_Install..JPG, which shows the location of leds and resistors required. Depending on what LED you use will determine the resistor value, The XR Ble that I sell should use 380ohms where as most 1206 smd leds should have a value of 470ohms. If you are buying your own led's make sure you get the makers specs and refer to them to get the correct resistor value. The extra pin can be made out of Size #3 solder-wick(from Altronics or similar), by simply applying solder to the wick until it is solid. Cutting it to the appropriate size and inserting it from the back , then through the circuit board. Its quite fiddly but it can be done.For a 2 Window switch refer to Ute_Multi_Install.jpg, which shows the location of the upgrade board, leds and resistors. Use the same figures as the 4 way switch for resistor values etc. The single switches are pretty much the same for 4 window or 2 window version except you need to install an extra pin for a 4 window version. Use Size #3 solder-wick again, seperate the circuit board from the plastic bottom and bend the new pin to suit the others, solder it in place. Refer to Single_Sedan_Install..JPG.The 2 window version needs a link installed as per Single_Ute_Install..JPG but no extra pin is required.You can test the illumination before you put everything back together by plugging into your loom.Once tested reinstall all the switch mechanisms, Install the top cover of the switches,(try to keep the part you press centralised as you are installing as it makes it easier to get it right the first time).Re install into vehicle and test all windows and illumination.They should look something like 4Way_Illuminated.jpg and Single_Illuminated.jpg.I hope this guide helps.More to follow.Matt 1 Link to comment Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 18y 9m 27d Gender: Male Location: Melbourne Posted 29/03/07 10:09 PM Author Share Posted 29/03/07 10:09 PM Just to let you all know, I am currently out of XR Blue LEDs. But I have sourced some that may work which I should receive in a week or 2. I'll let you all know.Matt Link to comment Share on other sites More sharing options...
scott52 Member 188 Member For: 21y 3m 3d Gender: Male Location: Perth, W.A. Posted 30/03/07 10:13 AM Share Posted 30/03/07 10:13 AM I bought 50 SMD 1206 blue LED's from here. Used 430 ohm SMD 1206 resistors from Altronics.Worked a treat. You can buy the blue SMD led's in lots of 50, 100 or more.Top Bright LEDCheers,Scott Link to comment Share on other sites More sharing options...
scott52 Member 188 Member For: 21y 3m 3d Gender: Male Location: Perth, W.A. Posted 22/04/07 11:35 AM Share Posted 22/04/07 11:35 AM I added a red led for the rear cut off switch. The positive side of the LED goes to the pivot mount for the cut off switch (see photo). Use a standard 430 ohm resistor on the other leg and connect to the "new pin" pad. I used a Jaycar surface mount red LED "Gull Wing" style 70 mcd. Part No. ZD-2000. Mount the LED just off centre so the switch doesn't cover it.Cheers,Scott Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 19y 7m 3d Gender: Male Location: Perth, WA Posted 15/05/07 11:45 AM Share Posted 15/05/07 11:45 AM (edited) Here is the how-to zip I made a couple of years ago... it was originally posted up but got lost in the worksHappy soldering!Zip File Edited 15/05/07 11:47 AM by XXXR6T Link to comment Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 17y 4m 19d Gender: Male Location: Perth, NOR Posted 15/05/07 11:07 PM Share Posted 15/05/07 11:07 PM Nice guide! Cheers for that.Just curious if you can achieve similar results from painting the underside of the switches blue with light globe paint for example? Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 19y 3m 25d Gender: Male Location: SoR, WA Posted 15/05/07 11:33 PM Share Posted 15/05/07 11:33 PM I bought 50 SMD 1206 blue LED's from here. Used 430 ohm SMD 1206 resistors from Altronics.Worked a treat. You can buy the blue SMD led's in lots of 50, 100 or more.Top Bright LEDCheers,ScottAre these the ones you boughthttp://www.altronics.com.au/index.asp?area=item&id=R8089 Link to comment Share on other sites More sharing options...
scott52 Member 188 Member For: 21y 3m 3d Gender: Male Location: Perth, W.A. Posted 16/05/07 03:33 AM Share Posted 16/05/07 03:33 AM Are these the ones you boughthttp://www.altronics.com.au/index.asp?area=item&id=R8089Adrian,Yep ... they are the resistors I bought. The LED's are hard to find ... that's why I got them off eBay.Cheers,Scott Link to comment Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 18y 9m 27d Gender: Male Location: Melbourne Posted 16/05/07 04:03 AM Author Share Posted 16/05/07 04:03 AM XF Falcon, Ive been told by painting the top of the White LED's using blue glass paint works, still I would think the colour would be a little off. I wouldnt be painting the underside of the switch though.As for XR Blue LED's, You struggle finding these at any reasonable price unless you are willing to purchase 3000+. That is why I have run out, I have to wait until someone orders these and then I buy a few extra. You can buy similar to XR blue from Farnells I think, but they are like $5-10 each or some silly amount like that.Hope that helps.Matt Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 19y 7m 3d Gender: Male Location: Perth, WA Posted 17/05/07 02:17 AM Share Posted 17/05/07 02:17 AM Yeah I dont understand that hey, for some reason everywhere just stopped stocking the blue SMDs... used to be able to get heaps at Jaycar. Maybe an overseas supplier? How much for 3000? Link to comment Share on other sites More sharing options...
