Paradoxx Colossal Member Member 5,049 Member For: 19y 7m 5d Gender: Male Location: Perth, WA Posted 03/04/06 01:35 AM Share Posted 03/04/06 01:35 AM What I dont understand is how you can have two identical vehicles with similar km running the SAME tunes and the SAME fuel, having vastly different power figures. Is it design? Quality Control? What gives us this difference? Link to comment Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 20y 11m 3d Location: Geelong Victoria Posted 03/04/06 03:04 AM Share Posted 03/04/06 03:04 AM (edited) What I dont understand is how you can have two identical vehicles with similar km running the SAME tunes and the SAME fuel, having vastly different power figures. Is it design? Quality Control? What gives us this difference?<{POST_SNAPBACK}>I think the difference in power is purely down to factory boost pressures. The ones who make more always seem to have a little bit more boost than the lower powered ones. That would be caused by a variance in whatever controls the boost levels. Then there is mechanical variances between engines. There are always some engines that go that little bit better than others due to slightly different tolerances. Some engines may have slightly bigger bores, cams, bigger and smoother ports etc. They may be only thousands of an inch bigger but combine them all and you may get a few kw's difference between engines. Same goes for % of loss through the driveline.Run procedure also comes into play. Edited 03/04/06 03:06 AM by Venom XR6 Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 20y 7m 10d Gender: Male Location: Zombie Birdhouse Posted 03/04/06 03:07 AM Share Posted 03/04/06 03:07 AM Manual Phoon 228rwkw completely stock Link to comment Share on other sites More sharing options...
XRBloke Donating Members 1,219 Member For: 20y 9m 3d Posted 03/04/06 03:48 AM Share Posted 03/04/06 03:48 AM We have seen a few 6 Speed Typhoons bring some big number stock, do you think that Ford have fudged the 270 kw output a bit to keep it under the GT?From the results given and the times it would make you think that perhaps they are underated by atleast 10 - 15 flywheel kw. Link to comment Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 19y 7m 5d Gender: Male Location: Perth, WA Posted 03/04/06 05:12 AM Share Posted 03/04/06 05:12 AM The thing is they are designed and produced to put out a set power figure at the fly as a minimum figure, and losses through the driveline will be slightly different for each car. If they brought out the cars with a tolerance of 240kw +/- then it wouldnt be the best way to advertise. If they bring it out as a minimum figure then it wouldnt matter what the actual figure is cos the customer will be happy anyway. Link to comment Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 20y 11m 7d Gender: Male Location: stanthorpe wine capital of qld. Posted 03/04/06 06:25 AM Share Posted 03/04/06 06:25 AM Our auto 2002 model was 176 rwkw's standard.Now 326 rwkw's.Ian Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 20y 7m 10d Gender: Male Location: Zombie Birdhouse Posted 03/04/06 07:40 AM Share Posted 03/04/06 07:40 AM I know of an F6 that made 245 rwkw stock (auto)<{POST_SNAPBACK}>cough.....bull Mr Happy Dyno Link to comment Share on other sites More sharing options...
O2STOCK Donating Members 607 Member For: 18y 6m 15d Location: Brisbane Posted 03/04/06 08:01 AM Share Posted 03/04/06 08:01 AM (edited) Stock 2004 Auto RWKW was 196.4 Optimax 98No Mods Edited 03/04/06 08:02 AM by O2STOCK Link to comment Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 20y 1m 28d Gender: Male Location: brisbane Posted 03/04/06 08:30 AM Share Posted 03/04/06 08:30 AM stock 199.6 rwkw... no mods to mention (6 speed manual) Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 3m 5d Gender: Male Location: Perth, WA Posted 03/04/06 08:34 AM Share Posted 03/04/06 08:34 AM My mk1 auto made 173 rwkw prior to mods. At the time several compared manual T5's were making 190-195 rwkw in std. configuration Link to comment Share on other sites More sharing options...
