XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 6m 28d Gender: Male Location: Perth, WA Posted 30/09/05 12:18 AM Share Posted 30/09/05 12:18 AM Hey guys,On the way to work this morning about 10km from work I noticed that my speedo was not working and the "D" (for Driver) was flashing. I moved the auto selector over to SSS mode but this made no change the D was still flashing. I could not fell that the car was changing gears, but I got up to speed of about 60km/h and the engine was still below 2000rpm, techo was working. Also I could not set the cruise control and no other warning lights at all.Got to work, turned the car off, started it back up again and moving the gear selector to D and over to SSS was fine again. Did not flash or anything and no warning lights or anything. Did not have time to drive it because I had to run into the office!What could it be?? Cheers! Link to comment Share on other sites More sharing options...
Master G Donating Members 511 Member For: 20y 5m 28d Gender: Male Location: Sydney NSW Posted 30/09/05 02:12 AM Share Posted 30/09/05 02:12 AM The Flashing D is the Auto limp mode signal, I have found it occurs occasionally with mine but that's due to the torque my box is handling. I normally find that turning it on and off resets the issue at least on standard boxes. Your ford dealer should be able to tell you more, well a decent one should be able to.RegardsM G Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 6m 28d Gender: Male Location: Perth, WA Posted 30/09/05 02:34 AM Author Share Posted 30/09/05 02:34 AM The Flashing D is the Auto limp mode signal, I have found it occurs occasionally with mine but that's due to the torque my box is handling. I normally find that turning it on and off resets the issue at least on standard boxes. Your ford dealer should be able to tell you more, well a decent one should be able to.RegardsM GYea hope I can get home ok tonight!!! I am going to take it to a dealer in the morning and hopefully they can get some fault codes of it and find out what the problem is!! Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 3m 27d Gender: Male Location: Perth, WA Posted 30/09/05 03:20 AM Share Posted 30/09/05 03:20 AM I had this happen when I first started playing with mods Mine locked out some gears, and would not allow me to use the SSS mode either. I think it does this if some parameters are too far outside expected values, but switching the car off and then back on should clear it.If it happens often, you may want to get it looked at. Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 19y 7m 11d Gender: Male Location: Mildura Posted 07/10/05 05:21 PM Share Posted 07/10/05 05:21 PM stereo not working and "D" flashing??PM "jetmir" I think he knows how to fix this. Link to comment Share on other sites More sharing options...
xrdreaming Lifetime Members 1,693 Member For: 21y 2m 21d Gender: Male Location: Melbourne Posted 07/10/05 09:35 PM Share Posted 07/10/05 09:35 PM While the D is flashing the auto locks itself in 3rd gear Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 20y 6m 28d Gender: Male Location: Perth, WA Posted 08/10/05 05:50 AM Author Share Posted 08/10/05 05:50 AM stereo not working and "D" flashing??PM "jetmir" I think he knows how to fix this. Mate "speedo" not "stereo" .........give the guy a break! I took the car to a dealer the following morning and they found what the problem was. Reason why it went into limp mode was because I lost my speedo and the reason for that is a loss of signal from the gearbox to the ICC. This was due to moisture in one of the electrical plugs near the gearbox (what they told me). They cleaned it up and reset the error codes and I was on my way. No problem since, they speedo works all the up to hehehe. Link to comment Share on other sites More sharing options...
jEtONiT Donating Members 1,817 Member For: 20y 5m 12d Gender: Not Telling Location: next door.. Posted 08/10/05 08:00 AM Share Posted 08/10/05 08:00 AM stereo not working and "D" flashing??PM "jetmir" I think he knows how to fix this. Link to comment Share on other sites More sharing options...
JasmineAlmalki New Member 1 Member For: 2m 28d Posted 22/01/24 10:05 PM Share Posted 22/01/24 10:05 PM Having the exact issue with my Ford Territory at the moment 😅 so glad I found this info, going to mention it to the mechanic if he tries to pull a fast one on me Link to comment Share on other sites More sharing options...
